2009 TL SH-AWD transmission fill plug
I was changing oil and differential fluid and was thinking about doing transmission too. I found the drain plug but couldn't find the fill plug. Can anyone in TL land help me out?
See below link: Item 12.
CASE, TRANSMISSION/AT TRANSMISSION CASE (5AT) for 2009 Acura TL
Either a 17 or 19mm socket with long extension(s). Will take a great deal of torque to open the first time.
On Top
Your fill plug is on top of the transmission 17mm and a crush washer you should get 4 qts of Acura transmission fluid and a new crush washer at the dealership. Your going to need a long extension and a ratchet you might need a piece of pipe for your ratchet for leverage when taking the fill plug off dont worry it will come off . When you replace the fill plug use a little anti-seize on the threads of the fill plug so next time you change fluid the plug will come out easy.....word.
cycdaniel
12-17-2019 10:58 AM
