2009 TL - Remote Start
Hi All,
Newb here![Wave](https://acurazine.com/forums/images/smilies/wave.gif)
It's getting pretty cold now and I want to get a remote starter for my wife's 09 TL with tech package. What is a good option if I want to use the factory remote?
Thanks!
Newb here
Thanks!
The dealership can do it, but they list the cost of the OEM remote start at $942.00 Canadian (installed). You could always call them and see what they quote you at, they might cut you a deal since the car is no longer in production.
Well here's an eye opener for you, remote start isn't cheap, I know this from experience. Even a cheap econo car will cost you $350+ for remote start. If you do find a low cost option fill me in because I don't think they exist.
Damn sorry to hear, I thought they might cut you break on the price. The problem with all the starters at your local Future Shop and Best Buy is that they use their own shitty remotes. You'll probably have to go in and actually talk with a shop that specializes installing them to get a clear answer on what's out there (if anything) that lets you keep your factory key.
Most places in my area charge around 350-400 for remote start with a smart key. There is no additional fob, they program your stock fob somehow and you're good to go. The one I bought for my wife only needs the lock button pushed three times and it starts right up.
I don't remember off the top of my head, I have to look through the paperwork on it. Most car audio shops offer that option. I would go to one in your area with a good reputation and ask them about what brand/s they offer and options.
The brand is avital model 4103, it's been working great for two years now. I know there are other brands out there. Viper makes one but I believe they are closer to 500 installed.
Found this on Amazon, but you're better of talking to a shop I wouldn't attempt to install something like this yourself.
Got the viper for $150
Viper LED 2-Way Remote Start System
How much should install cost? ... Lowest I've been quoted is $250 for the module, programming, labour etc...
The factory acura remote start fob is fairly large ..I never actually put it on my main key chain , usually throw it in my gym bag or coat pocket . It does have some nice features though , and it gives you a certain peace of mind being a factory acura part.
Go to an Acura dealer to have this installed. Its not the hardware installation that worries me, but the software/firmware upgrade required. I am sure all professionals non-Acura certified dealers are very good and do a good job. However, if that software/firmware upgrade gets messed up then you are looking at some major problems. Plus, if you are still under warranty and something bad happens, I seriously doubt that a mama and papa shop can afford the liability to fix a $6k computer, or that a real Acura dealer will cut you any slack with the warranty of the car when they see what happened. Also there are implications with your insurance company, check the fine print before installing non-dealer electronics with access to vital systems of the car.
... just a thought.
... just a thought.
Keeping TL until 2029
This is a post to check out. It is expensive but nice to have in the winter.
https://acurazine.com/forums/audio-b...-start-899047/
2014 TL SH-AWD Advance
Amazon.com: Add Remote Start To Your Acura TL or ILX Push-To-Start Vehicle. Uses OEM Fob.: Automotive
What about the Viper/Clifford SmartStart system? It's $149 and works with a smartphone app.
Viper SmartStart
Viper SmartStart
I installed the factory remote starter myself. The installation took me a couple of hours. There is a step-by-step instruction manual made by Acura that even tells you where to put zip ties. It's that easy.
Programming the immobilizer module took 10 minutes. But to do that you need the HDS HIM.
One review on Amazon for this. I know it shuts off when you open the door as it doesn't have the ability to do "takeover" or whatever. However, is your remote fob really disabled if you remote start it?
Most Helpful Customer Reviews
3 of 5 people found the following review helpful
Designed by a moron, should be fired.
By J. Sawyer on August 21, 2013
If you remote start the car, you cant unlock it with your remote fob, it is disabled. If you unlock the door with the key, the car turns off. Whoever designed this system for Honda should be fired.
How much does the OEM autostarter go for without it being installed? It seems like an easy install so realistically I'm down to just buy it and install it myself.
However, even with these imperfections, the remote start is a much better choice IMO. There is no cutting/tapping into wires. The install is clean and completely reverseable. I also like the feature of the factory RS that turns on your heater and defogger once it detects the outside temperature.
Returned the viper... the installer is suggesting going with Compustar... So I'm still up in the air on which route to go... I want the safest... but don't want to pay $900 either.
My main concern now is the warranty on the TL just ended... if something gets messed up, it will be problem... is this rational or just being paranoid?
Bought mine on Ebay for about $380 delivered. And yes, there are some unrefined things on the factory RS. As mentioned above, you cannot do a takeover. The car shuts off when you touch the door handle. This is something I really dislike as I don't like putting extra stress on the starter.
What components are required for the factory setup? The link posted earlier shows a remote start module, but are there other things? Does the dealer have to program something for the OE module to work? I'm fine with it shutting off and I certainly like the thought of it starting the defrost automatically.
Got my factory remote start from Benardi Acura Accessories online store for $384 and free shipping. The install took approximately 2 1/2 hours and if I can do it, pretty much anyone can. Everything is plugged in under the dash and steering column. I went to my local dealer for my oil change and told them my remote start wasn't working. They programmed the fob as a courtesy and I'm all set. Everything works great and I am already enjoying it.
Acupower,
1. Remote fob
2. RS module
3. Harness (also known as Attachment)
The harness is specific to the model and year. I believe 09s and 10s share the same harness BUT the Tech and Base model have different harness. If you buy online just make sure you contact the seller and ask them.
I bought the whole set of parts from Ebay. It was a posting like this:
2009 2011 Acura TL Tech Model Remote Engine Starter Attachment NEW OEM | eBay
The package I got from ebay came in with absolutely everything. And I mean everything - down to the properly sized zip ties and clips.
Finally, you will need to register the RS module with your immobilizer after the install. If you don't have HDS HIM interface, you WILL need to go to the Dealer and get it programmed. I was fortunate because I bought the HDS a while ago to do other diagnostics and I was able to use it to program the module with no issues.
Hope this helps and good luck.
No it can't. There's no lock or unlock feature on the remote start key fob either.
ncxvtguy83 (12-03-2014)
You need 3 main components for the OEM install:
1. Remote fob
2. RS module
1. Remote fob
2. RS module
Just to be clear (since this response is potentially misleading), the factory remote start fob does have lock and unlock buttons; it simply won't work as true keyless entry (unlock when your hand goes behind the handle).
![](http://www.acurapartssuperstore.com/images/lg/Honda_Remote_01.jpg)
Perhaps they changed it, though I don't know why they would. I know my remote start won't work if the car is unlocked, so the remote has to be able to lock the car, for mornings like today, when I realized upon trying to start that I left it unlocked all night.
Mine's the same. Weird...until you posted the picture, I never noticed that they eliminated the "panic" button.
Andrew, as I recall, you drive a 2009 as well; was your remote start added only recently?
I haven't installed/bought mine yet but I was just looking around to buy OEM one and that's the pic that showed up lol.
oyayjoe
09-12-2015 04:40 PM
siularbar
1/2G MDX (2001-2013)
09-11-2015 10:40 AM
