2009 Acura TL Key FOB Battery Change?
Old 11-14-2011, 09:23 PM
niravp44's Avatar
Has anyone changed their TL key fob battery? if yes please advice on how to change it.
Old 11-14-2011, 09:39 PM
9th Gear
gkeis's Avatar
Keyfob battery replacement
On the keyless fob, the battery is easy to replace. Just remove the built-in key and then pry open the case using a coin in the slot next to where the key inserted into the case. The coin battery is a CR2032. Snap case back together once you replace the battery. I just did my 2009 TL fob about two weeks ago.
mel88hrman (07-27-2012)
Old 11-15-2011, 09:04 AM
niravp44's Avatar
Perfect!. I found this as well. Thanks
Old 11-15-2011, 12:39 PM
potmilkz's Avatar
Received 1,021 Likes on 793 Posts
you dont need to change the battery!!! you charge it in the key slot in your car!!!
Old 11-15-2011, 06:53 PM
BigBunks's Avatar
really????
Old 11-15-2011, 06:54 PM
lji
lji's Avatar
NO!! ... lol
Old 11-29-2011, 08:10 PM
Beeper27's Avatar
It is in the manual. It does not charge the key.
Old 11-30-2011, 07:32 PM
Qwikhas's Avatar
I changed mine since i didnt know how long it was in use and i didnt want to take any chances of it crapping out on me. I bought a six pack of batteries from ebay for $3 so i'm covered for a good while.
Old 04-13-2013, 11:36 AM
sapper_64's Avatar
Will you have to reprogram the key fob again if you do change the battery out? I've got 2010 tl
Old 04-13-2013, 11:43 AM
niravp44's Avatar
No. Just replace the battery and it will work.
Old 04-13-2013, 03:50 PM
BLEXV6's Avatar
I just had the dealer do it
Old 04-13-2013, 03:54 PM
JM2010 SH-AWD's Avatar
The car will give you a warning message if the fob battery is low on juice.
Old 04-13-2013, 06:10 PM
Hogan9166's Avatar
Mine didn't. Mine stopped working this week with no warning.
Old 04-13-2013, 07:08 PM
Odd. Mine gave me a message a couple of weeks ago. Drove it that day and replaced the battery the next day.
Old 04-14-2013, 11:09 AM
Bernie Gov't's Avatar
whatever you do dont by a battery from the dealer.. its like $7 lol when you can get it at CVS for $2 lol
Old 02-23-2015, 09:40 PM
JTL12's Avatar
is CR2032 the same battery for the 2012 fob with key?
Old 02-23-2015, 09:58 PM
andrewcjduong's Avatar
Get legit batteries like name brand Energizer or Duracell. I bought Ikea ones. They last like a month.
Old 02-24-2015, 02:09 PM
The Professor's Avatar
If your fob battery does die you can always insert it in the ignition slot and still be able to start your car, it's good to know just in case.
Old 02-24-2015, 03:39 PM
sockpuppet's Avatar
This post made me smile. Then, I wept, realizing that it might be serious.
Old 02-24-2015, 04:05 PM
'99-6SIC6's Avatar
If I could only tell you just how many key fob batteries we change here at the dealer, you'd be amazed. It's incredibly simple yet so many clients refuse to even attempt it. We keep a specific set of mini eyeglass screwdrivers at the retail parts counter for this task alone. And yes, the batteries you get at the dealer are quite expensive. They are made by Panasonic, in case anyone was wondering.
Base Model TLs take a CR1616 and the OEM part number is - 72148-S0A-000 : $6.94 each
Tech Model and above TLs take a CR2032 and that part number is - 72148-SNB-000 : $10.46 each
-greg
JTL12 (02-24-2015)
Old 02-24-2015, 07:53 PM
Grez007's Avatar
Yes sir, did mine a couple weeks ago... No need to reprogram
Old 02-25-2015, 06:32 AM
vinnier6's Avatar
Same battery in most garage door opener remotes if you are in a pinch
Old 03-03-2015, 12:00 PM
6th Gear
idgamerd's Avatar
sucks that it doesnt charge; i was wondering about that as well as when i plug the key in the warning of low battery stops appearing
Old 11-01-2023, 10:13 AM
Ivantl's Avatar
My battery was a cr1616
base model TL
mada51589
05-03-2022 08:54 PM
02-25-2020 09:57 AM
tman570
06-11-2019 07:56 AM
nanos
11-12-2015 08:41 PM
asahrts
09-04-2015 05:55 PM
Quick Reply: 2009 Acura TL Key FOB Battery Change?
