MDX brake fluid
Old Oct 9, 2021 | 05:32 AM
hontoria's Avatar
7th Gear
MDX brake fluid
22 Acura MDX dot 3 or 4 does it need to be Acura grade fluid as it states in the manual or it could cause corrosion in the system
Old Oct 9, 2021 | 07:54 AM
DOT 3 only.
if you look at the brake fluid reservoir, the cap will say DOT 3 ONLY
it can be generic brake fluid, it doesnt have to be Honda brake fluid, as there is nothing special with brake fluid
Old Oct 9, 2021 | 08:58 AM
hontoria's Avatar
7th Gear
Thanks again.
Old Nov 26, 2021 | 05:09 AM
E92Vancouver's Avatar
You need to add brake fluid already???
Shasta17*
3G MDX (2014-2020)
Aug 12, 2021 10:50 AM
na4acura
3G MDX (2014-2020)
Mar 22, 2021 07:00 PM
Kevin17112
3G MDX (2014-2020)
Mar 14, 2019 12:49 PM
vij_mdx2015
3G MDX (2014-2020)
Aug 18, 2016 08:02 AM
91bulldog
1/2G MDX (2001-2013)
Nov 30, 2012 06:13 PM
