Cargo dimensions?
Moderator Alumnus
Cargo dimensions?
Can someone with a 2022 mdx measure the cargo dimensions?
All the specs mention volume, but I'm more interested in length,width,height.
I found the Alexonautos review noted the length was 79.5 inches with the front seat all the way back)
what about all the way forwards? what if it's folded down and I put something on top of it?
(I've managed to bring home 6 foot ikea shelving in my g37x this way)
Also, can someone measure the dimensions of the under storage area? (in particular, the depth)?
It's surprisingly hard to find these numbers. I suppose 'at widest point' is the best they can put, even though it's potentially misleading.
Thanks,
Frank
Thanks,
Frank
I can only add that while checking out the MDX my notes indicate the cargo area measures 45" wide between fender wells, which is the same as the last generation. I did not check height.
Moderator Alumnus
I had to move a largeish ikea box today, and did some measurements as a check:
Note the front seat barely tilts forward at all.
It does lean pretty far back.
Various notes: (remember surfaces are curved so there's a +/- for all measurements)
start of the cargo mat to back of 3rd row: 22 inches
(didn't measure second row, sorry)
cargo mat to back of front row: 82 to 90 inches. (front seat only moves 8 inches)
cargo mat to 'mode selector button': 116.5 inches (assuming you want to lay something down the middle of the car).
width of 'hole' in second row if the middle/passenger side are down: 29 inches.
width of entire cargo bay: 45 inches between wheel wells. (higher if you sit on top, I guess)
height of cargo bay: 29 inches.
I had to move an ikea box that was roughly 24 x 97 inches. (for a 40x93" cabinet).
I was able to comfortably (?) do so by folding the center/passenger side of the second row down,
laying the front passenger seat all the way back, and taking out the headrest.
Then the box lay on top of all that. It fit no problem.
I think you could even get something 120-130 inches long if you really had to.
The following 2 users liked this post by ChodTheWacko:
jeffery4182 (01-07-2022),
wahoowa (11-21-2021)
Can I put a 42x100 sheet of glass in the cargo area with 2nd row laid down?
lmacmil
08-10-2015 10:15 AM
digity
3G MDX (2014-2020)
04-05-2014 09:15 AM
