WW3 just began
Old 03-04-2009 | 10:49 PM
whitedrgons's Avatar
WW3 just began
hey guy i just contact the falken tire coperation and they send me to 1 of they dealer near by which is Discount tire, so i take it in and 1 of the guy work in there take a look at the wheels and he say it a roadhazard and it not a defective tire and then another guy work in there come by and take a look and he say it a defective tire and im like WTF???? well after the first guy explain to the 2nd guy then he say it a roadhazard also. and i told them that i take my car to SUNberg's Automotive and did a test drive and take a look at my wheels and found front tires to be defective on the inside tire seperated and it cost me $52.74 total and i still had my recieve with me and i show it to them and then they started to piss and say that the ppl work at SUNberg Automotive dont know what they r talking about and started to say that they r professonal tire something like that. and i say it to them if it a roadhazard y it only happens to the front wheels and not happen to the rear wheels? i mean if for some how i run into the pothole or anything like that then it woulda been happens to both front and rear wheels?? and then they started to ask me / blame on me by ask me wht preasure im run for the tire i told them i did 37psi all around and they say i sure run 40 psi that wht on the tire said and they kinda laugh at me abit and i told them that i know alot of ppl / Azine that had run even low preasure then i did and they didnt had any problem at all. and then they r Bitching alot and even alot more. bitching.
oh 1 thing that i didnt give out more detail is my wheels brand and side tires. my wheels r Sevas wheels S55 custome color gunmetaland im run Falken FK-452 tires 225/30/20 in the front and 255/30/20 on the rear.
so did any1 w/ Saves wheels have the same problem like i did w/ the rims/tires spec i did???. or any defective tire like i did? i would like to find this out.
so over all SUNberg's auto said it defecvtive and Discount tire say it roadhazard> so who is WTF? ill post some pic so r Azine can take a look at. so wht if my wheels is it a roadhazard??? wht it gona happen? is that mean it cover no nothing? can any1 help? explain?, idea? help, momy help?
ok up above r my old thread when i first big fights w/ Discount Tire. and now is another 1 which i would like to calls is world war 3 (WW3) just began be cuase it sound fun as hell?
ok this is my 2nd times that i had a big fights w/ Discount Tire, wells today i just got my Brand NEW both front 2 tires (falken fk452 side 235/30/20 which is abit bigger then my previous old tire i had on) so i take it to Discount tire againt to mount the new 2 tires i just got today around 6 oclock pm so it take them about 40 min or so, finnaly it done and it about 7 and was prety dark out side so i didnt take alook very detail on the wheels and my Old 2 tires. so i ask them is every alright? the guy that mount/dismount my tire saying they had a bit difficult time mount it and dismount the tire since the tire r 235/30/20 on a 8.5, 40mm offset, and he also said that my old tire 225/30/20 is much easyer to mount and dismount then 235/30/20?? is that true? cuase i was thinks the oppisite. wells anyway he says every thing is good now. so i take it home along with my 2 old tires home which is look brand new its been use on the roads about 500-600 miles on it. "also remember 1 of r aziner wanna buy it, awhile back ago cause he thinks my 2 old tire is still goods, it just it needed to used on the 20" wheels that had less offset, is that true that i can still make some dollars on my old tire?( it a minor roadhazard on the inside tire seperated)" while that is the reason y i told the guy that mount my tire that i want my old tire back. when i got home i was clean them and also take a looks at my old tire and i found that the guy that dismount and mount my tire, did a shity job and damage 1 of the wheels and i was check the tire presure there r no air comming out at all?. and also both old tires r in a very bad. i did take alot of pic and here r some pic so Aziner know wht im try to say and wht should i do w/ discount tire? and wht i should not ? cause WW3 will began tommorow when i get off work.
any idea any1?????????????????????????????????????
Old 03-04-2009 | 10:52 PM
here r the pic im not sure how to post the pic on here
princelybug's Avatar
LIST/RAMEN/WING MAHSTA 짱
Old 03-04-2009 | 10:56 PM
how u post pic Pricelybug?
Old 03-04-2009 | 11:08 PM
Old 03-04-2009 | 11:21 PM
Bearcat94's Avatar
AZ Community Team
You have to upload the picture to www.photobucket.com. Make an account there first.
Then copy the [IMG] ..... [/IMG ] link. Paste the link in your post.
BTW - use paragraphs when you post. You English isn't great and everything mashed together makes it even harder to read.
Old 03-04-2009 | 11:27 PM
Old 03-04-2009 | 11:47 PM
Thx bearcat94
Old 03-04-2009 | 11:58 PM
HERE MORE
Old 03-05-2009 | 12:00 AM
Old 03-05-2009 | 12:01 AM
TIRE
Old 03-05-2009 | 06:53 AM
ok this mornning i was take alook at the wheels that got damage and wondering y there r no air presure comming out. so i did compairison the 2 wheels and i found out that the damage wheels r look difference and abit wider then the other wheels, and y it look wider then other normal wheels? and y there r no air comming out? the reason is that i found out that there r no air pressure at all in the wheels. so my question is, when they done mounted dont they suppost to air pressure the tire then ballance the wheels? in this cast they forgot to air presure the wheels.
from my home to Discount tire is about 2 min away.
Old 03-05-2009 | 06:54 AM
another problem is about the old 2 tire but ill talks about it later becuase im at work and not suppost to bitching on the net lol
thx
Old 03-05-2009 | 07:58 AM
luckyAKAhappy's Avatar
My baby's ride...
Wow...hard to understand what you're typing but did they mess up your wheels or are you claiming the tires are defective which caused the damage to your wheels? Either way...it sux that it's damaged.
Hopefully you'll be presenting a much clearer case in person.
Old 03-05-2009 | 08:57 AM
JMillerUA6's Avatar
Chapter Leader (New England)
I'm so confused......
Old 03-05-2009 | 09:27 AM
jimsta's Avatar
NTMD8
I re-read this a few tiems and I am having trouble understanding this as well... but from the looks of the pictures and what I can understand.... you had disagreements with them before and the 2nd tiem you went in to change tires, they fuqed up your new rims and scratched them up... and your old rims.... also got fuqed up.
Old 03-05-2009 | 09:44 AM
paz840's Avatar
Originally Posted by jmillerua6
i'm so confused......
+1
Old 03-05-2009 | 09:48 AM
Majofo's Avatar
???... :walksawayslowly:
Old 03-05-2009 | 11:23 AM
DMZ's Avatar
DMZ
Head a da Family
Whitedrgons,
This car was not designed to accomodate 20 inch wheels. That's one of the reasons you're having these problems and will continue to have them no matter which 20" wheels or tires you install.
Getting super pissed off at and starting WWIII with the tire place is only gonna dig you a deeper hole, GUARANTEED.
No offense, but from your English, it doesnt seem like you made it past the 6th grade. How old RU?
Old 03-05-2009 | 11:29 AM
sorry for confused. ill make new thread and re-writed everything in paragraphs and hope ppl can understance better. can some1 close this thread? plz
thx
Old 03-05-2009 | 05:25 PM
wooooooooooooooooooot /victory......................i win.
Ended WWIII with just me and 2 of my friends nuke the shit outa Discount tire for 2 hours of raiding. and finaly they willing to pays the repairs cost on the damage wheels. dose any1 know is there a good place that dose rims repair locate in MN, Twin Cities, Minneapolis - St. Paul?
thx
Old 03-05-2009 | 05:41 PM
jjashaa's Avatar
Avant Garde Wheels
next time.. or EVERYTIME you get tires mounted.. check before you leave.. because they can say the damage could've been caused while going home..
same thing for paintjob, check before you leave and other stuff..
Old 03-05-2009 | 05:44 PM
Custom paint/repair rime shop locate in mn, twin cities?
dose any1 know is there a good place that dose COSTOM paint/rims repair locate in MN, Twin Cities, Minneapolis - St. Paul? this rime below need to be fix.
thx
Old 03-05-2009 | 05:47 PM
thx jjashaa. i know now lol
Old 03-06-2009 | 07:19 AM
My baby's ride...
Good for you. But it seems like a bittersweet victory. They'll pay for the repair but you don't know where to get it repaired. Hopefully you got it in writing that they'll pay for repairs with no dollar limit, or there might be WW4
Old 03-06-2009 | 07:36 AM
jweb12's Avatar
I couldn't make it through the OP's posts without getting a sharp pain behind my eyes. But, I think I got the basic premise. Glad you were able to get this issue somewhat resolved.
In the future, if you would like constructive advice/input from this community, I would strongly suggest taking your time and creating a post that at least adheres to the basics of common grammar. Nobody here expects every post to be written perfectly, but you'll get more confusion than help with posts like the first of this thread....
Old 03-06-2009 | 12:28 PM
Fulani has a TL's Avatar
I was dazed and confused after reading all these threads....
But in actuality, NEVER take nice rims to Discount Tire or whatever chain you are thinking about... They gonna scuff/scratch/gouge your rims.
Plus, you CANNOT I repeat CANNOT drive 20's that have 30 series tires like they're OEMs. Plain and simple
Ok done ranting
Powder Monkey
2G CL Problems & Fixes
09-09-2018 12:55 AM
hedzup
1G RL (1996-2004)
06-29-2016 08:07 AM
Kitsune13
09-24-2015 02:25 PM
PortlandRL
09-14-2015 12:01 PM
Quick Reply: WW3 just began
