Work emotion cr kai...
Stand For Something
The A-Spec suspension does not lower the car an inch, no matter which one you get. So don't expect it.
All Cr Kai wheels clear the OEM Brembos. I'm pretty sure they are offered with a +30 and +35 offset, if it were me I would get the +30.
Yeah 18 is the biggest they offer. I'm probly going to go with the m/t a-spec first then wheels. Still debating on the works...I'm looking for something that will improve performance and not be too flashy. i really like the look of the stock type-s wheels and I thought the cr kai's look similar. What do you guys think?
Just to be clear (I'm a newb to the whole offset concept), the higher the positive offset the further out from the center of the car the wheel will be, correct? Also, is there a type-s aspec suspension and base aspec suspension or just one aspec suspension for both models?
Old thread, but its time to revisit this subject I have decided to go with 18x8.5, but am wondering what offset I need on an 8.5in wheel to get a flush look. I would rather have the wheel tuck slightly than stick out of the wheel well. So basically, I'm looking for a flush look but conservatively speaking a slight inset from the wheel well would be ok. Thanks in advance.
edit: will 255's fit on an 8.5in wheel?
Stand For Something
You post an example of how you want your wheels to look; the example you give involves significantly stretched tires and negative camber.
THEN, you say that you don't want the wheel to stick out of the tire....??? Do you not see the rear wheels in that picture? You didn't notice how the rim of the wheel is completely poking out of the tire?
If I recall correctly, bforbrian (that's his car you posted) was running a 10.5" wheel in the back with 245 tires. Yes, that is a pretty big tire stretch, but that is what is necessary to get the flush look that you supposedly want.
I suggested you run a 235 tire on an 8.5" wheel. That is not stretching a tire at all. Not in the least bit.
I think you need to figure out exactly what you want.
I need a car in
1 Post
^ yep u took the word out of my mouth of what i was going to say. i was going to give input but it seem u dont know what u want. there is no way achieving the flush look while being conservative. take your pick!
What the hell? You serious man? You just completely contradicted yourself...
Stock
I was originally gonna go 9.5 all around but I decided the weight diff between 8.5 vs 9.5 wasn't worth it. I think 9.5 +20 should fit.
mada51589
05-03-2022 08:54 PM
Luis J. Rodriguez
09-12-2015 10:00 PM
ahsm
09-09-2015 08:35 AM
