Wobble after coilover install
Old Jan 27, 2014 | 11:47 PM
  #41
Chad05TL's Avatar
If the body of the car woobles over bumps or bounces unevenly, that is different than a tire that is out of balance or a vibrating axle. So, you all have to define the symptoms better.
I know if the rear toe-in is not set on the original post, then you have a massive toe-in problem. You're nearly on the ground.. But since you have a crappy phone camera like you said, then take another picture since its so easy. Odds are you still need a rear alignment because up 1.25 inches from that pic is still low
Old May 16, 2016 | 11:51 AM
  #42
AMTL's Avatar
Unfortunately i fall the latest victim of this wobble shit after lowering mine on coil SMH.
Old May 17, 2016 | 03:56 PM
  #43
Oh Sickest TL's Avatar
Jeff
Yea i got a little tiny wobble at 30 km/hr and thats it, then it goes away . Weird
Old May 26, 2016 | 09:31 PM
  #44
HQTL6SPD's Avatar
Did you guys unload your suspension bushings during the install? There could be a high torsional load on them now after you went lower.
Other than that, check your control arms, sway bars (along with all other suspension arms..) ??
Old Nov 14, 2017 | 12:51 PM
  #45
jroca's Avatar
Angry
Originally Posted by cokorote
So what is the ideal drop for our tl without the wobble or straining/stressing too much the axles?
Originally Posted by FamilyGuy
+1
Anyone know?
^^^Anyone can answer this?
Bump!
CAN SOMEONE PLEASE ANSWER THIS!?! I just dropped my car and it wobbles like hell from the passenger front. What is the ideal height for this shit to stop shaking when accelerating from 0-25mph?!?!
Old Nov 14, 2017 | 07:37 PM
  #46
BROlando's Avatar
Originally Posted by jroca
Bump!
Raise it slightly and find out??
This is kind of a strange issue to have, however...
Old Nov 14, 2017 | 10:10 PM
  #47
jroca's Avatar
ok, I'm hoping to have time to do that tomorrow. I'll post an update once I do. Thank you
Old Nov 18, 2017 | 10:18 PM
  #48
jroca's Avatar
Slight improvement raising it
So I raised it slightly now....still have vibrations accelerating until between 20 and 25 mph. Another problem though, I'm seeing leaks...cant really tell if its oil or tran fluid and I don't know how long its been happening
Old Nov 19, 2017 | 09:34 PM
  #49
BROlando's Avatar
^Do you have photos of how low you are?
I just scrolled up to the photos of OP's slammed car. Lol...if the car is having issues operating at that height...there's really no mystery.
I assume the leak is something unrelated. Did you just get an oil change? Where is it coming from and what colour is it? Is it just water from the AC condensation pipe?
1fatcrxnem1
22
Jun 1, 2018 01:23 AM
BoricuaTL
Apr 8, 2016 01:08 PM
james357
Feb 13, 2016 02:37 PM
nanos
Nov 12, 2015 08:41 PM
TxRzrBk
Sep 17, 2015 01:07 PM
