Winter Wheels for my 2005 TL
Old 12-01-2006 | 04:18 PM
arafi's Avatar
6th Gear
Has anyone tried other OEM Acura wheels for their 2005 TL?
I have an automatic and want to stick with OEM look and have looked at the 16" RSXrims and the 17" TSX rims.
Does anyone have experience on the bolt pattern/wheel offset with these OEM rims?
TIA
Asim
Old 12-01-2006 | 10:55 PM
ronaries's Avatar
I have a 05 TK automatic - I went with a set of tl takeoffs from an acura dealer. I looked for alternatives but came up with 2 many issues .... best bet was Tire Rack, but they were sold out at the time. The offset and brake location made any online out of area order for wheels a risky proposition - lacking expert help.
Since my wheels hardly saw snow last year, I can't give you a report of how well they worked! But I did buy the Blizzak lm-22 and it seems like a good ride.
Old 12-02-2006 | 08:12 AM
arafi's Avatar
6th Gear
Thanks, I am hoping for 16
I am hoping to get 16" to cut through the snow a little more than my 7". I have 2 extra TL rims, which I bought on ebay a while ago to replace a curbed rim. I like the look of the RSX 16", its a 5 spoke rim kinda like the ones we have adn they are not too hard to find. Acura made a lot of RSXs.
Old 12-02-2006 | 11:15 AM
arafi's Avatar
6th Gear
Red face Acura OEM 16" rim
Has anyone tried any Acura/Honda OEM 16" rims on their 3G (2005) Auto TL? (w/Nav, although not sure it makes a difference). I need to get some winter tires and would prefer a second smaller set (16")
I checked the Tire spec post, but it addresses larger size rims only (although there was a post regarding 16" snow tires that no one responded to)
Old 12-02-2006 | 12:26 PM
Actuary's Avatar
18,000mi. 29000km
114.3 x 5 205/60/16 215/60/16 215/55/16
thats what I'm going for
Old 12-02-2006 | 02:32 PM
arafi's Avatar
6th Gear
What rims are you using?
Old 12-06-2006 | 12:57 AM
MightyTL's Avatar
06 TL! / 05 R6
I got OEM 99' 16" Alloy Honda Accord Coupe Rims on winter tires...
They fit perfect for my auto 06...They even ride SMOOTHER since there not low profiles...
But, importantly! If yours is manual or upgraded your breake kit you might want to consider the sizing.
Old 12-18-2006 | 04:02 PM
arafi's Avatar
6th Gear
I have an automatic 2005 TL, so the bigger brakes on the manual tranny will not be an issue.
Do you know the specs on the Honda wheel? if not, what year and what model wheel?
I am interested in the bolt pattern and the offset. And am hoping to use a set of RSX 5 spokes
16" x 6.5"
5x114.3mm
The TL has a 17"x8" with a 45mm offset.
I believe the OEM 16" RSX wheel has 55mm offset
Old 12-18-2006 | 05:11 PM
Jim_sir's Avatar
The 16" OEM steel rims will work w/ auto.
My tire delaer got me OEM Honda take-off rims for a good price and the TPMS sensors fit with no problems, didn't have to adjust sensor mounting angle.
Old 12-18-2006 | 05:32 PM
leedogg's Avatar
RAR
Bleh, I ordered new all seasons (continental contiextreme contacts) for my stock 17" rims, which were rated highly for snow performance and this will be my winter setup (its not like I need pure snow tires in the dc area). When spring/summer comes around, I'll probably pick up new rims + tires tbd.
Old 12-18-2006 | 09:54 PM
ubnpast's Avatar
Why? It doesnt make a difference
Old 12-19-2006 | 10:01 AM
MightyTL's Avatar
06 TL! / 05 R6
Yes it does make a BIG diffrence...
If your tires and rims are 16"s or smaller then depending on the rim structure it can rub, scratch, move, damage or shift over the brake kit...
When I tested this... w/ 06' Auto (smaller brake kit) didnt have no problems...
But w/ a 06' Auto w/ Big Brake kit OR 05' Manual (Brembos) it was rubbing and touching the callipars of brakes.
Anyone correct me if im wrong...
Old 12-19-2006 | 11:17 AM
arafi's Avatar
6th Gear
You got it right, the manual tranny TLs have an OEM larger brake set up and a 16"wheel will not clear the caliper.
Old 12-19-2006 | 07:02 PM
ubnpast's Avatar
lol, you are right. Sorry, I thought you were talking about the tire sizes for some reason, I was like what does that have to do with anything
Old 12-20-2006 | 02:52 AM
MightyTL's Avatar
06 TL! / 05 R6
NP... But if the tires are for 16" wheels there most likely for 16" rims that wont clear... Had to learn the hard way... got so happy thinking I got such a good price (
$100) for new tires and rims didnt even check to see if it would clear my calipars....
rockyboy
08-04-2024 11:35 AM
handsom-hustla
11-13-2015 06:04 PM
Trav2390
10-20-2015 08:30 PM
DunesCreations
09-09-2015 01:03 PM
nuldabz
09-03-2015 06:49 PM
