Will this whells fit on my tl (video)
Old 07-10-2011 | 06:34 PM
EugenioSolprzano's Avatar
Hello guys i need help. I Want to drop my tl 1-2 inches but i don't know if the wheels will fit or rub, the tire specs are 19 inch rims with 25 offset and tire size is 235/35/19, I want to use coil overs. If any of you have the same set up can you post pics. thank u
http://www.youtube.com/watch?v=6yfmkg410EU
Old 07-10-2011 | 06:59 PM
rptls08's Avatar
WDP Type-S sitting on air
if you drop it you will need to have the fenders rolled and or pulled... here is a few pics of my set up with 19x9 front +21 and 19x10 rear +24
original setup with rolled and pulled fenders and no camber
after -2 camber was added to the rear
Old 07-10-2011 | 07:09 PM
How did you pull you fenders?
what kind of suspension are you using?
Do they rub?
Old 07-10-2011 | 08:07 PM
murph145's Avatar
if you get your fenders rolled or cut the inside bead off you will be fine running what you have.... my other rims were +25 and with a 235 and my fenders cut i didnt rub at all
Old 07-10-2011 | 08:59 PM
rptls08's Avatar
Tein basics. Doesn't rub after I added camber.
08-15-2019 12:58 PM
navtool.com
31
11-16-2015 08:30 PM
navtool.com
09-25-2015 05:15 PM
ROSSARONIE
09-22-2015 11:46 AM
Quick Reply: Will this whells fit on my tl (video)
