will theses wheels fit my 04 tl
According to the wheel/tire picture thread, +30 offset works with a tire as wide as 245. The back can probably fit a little wider tire since the wheel doesn't have to turn, but you will probably have to run different front & rear offsets (more in back) to make that happen. The real trick to running staggered tires, is finding two sizes that are the same outer diameter (if you believe the ABS/VSA computer need that)...
My Garage not
1 Post
on an 18x9 with a 33 offset, i mean u can put it on but it's gonna stick out past the fender in the back. you're gonna be rollin around with the froggystyle look and will probably scrub pretty bad especially if you're dropped. i really would say no, it doesn't fit.
nanos
11-12-2015 08:41 PM
