Will these volks fit the Type S?
they will clear the brakes. but overall wheels will sunken in the fender if you are dropped. i suggest getting (4) 25mm spacers that bolt on top of stock studs. this will provide you with wider stance and more flushed with the fenders.
they will stock out 7mm more than stock wheels.
stock 17x8 +45
your CE 18x8 +38
get 235/40, will be a little meaty, 225 will be barely stretching and will expose the edge of rim depending on tire brand.
stock 17x8 +45
your CE 18x8 +38
I would think 25mm spacers would cause for some rubbing if you were to drop it.
255 is too fat for an 8in width. that is considered "monster truck" meaty...
I'm on stock 8inch wide wheels with 235 tires running a 15mm spacer. The back tire is slightly tucked and theres about 10mm clearance to the fender. Running a 25mm spacer will be pushing it I think, but it would be VERY close especially running a 245 or 255 tire on those rims. I would say experiment with washers on the studs before purchasing any size spacer.
sockr1
10-01-2015 01:31 AM
