Will these TL wheels clear brakes of TL-S?
I have a tsx and I want to install a bbk from an rl
I know the tl-s waffle wheels will clear w/o a spacer
so if the waffles, clear, these should clear too but i'm trying to figure out if they have been used on a tl-s and will work?
thanks in advance
thanks in advance
All 3G stock wheels are 17x8 +45, so theoretically they should fit. Also, keep in mind that RL calipers are different sizes than the TL Brembos.
The '04-'06 TL wheels will fit with no probelms either the base or the Brembo equipped cars, but the ones shown here are from a '07-'08 base TL and although they will "fit", they reside too close to the Brembo calipers so will need a slight spacer to gain clearance to be in compliance with the Brembo recommened clearance. This is if the Brembos are from the TL.
I have the base TL wheels on my TSX with the TL Brembos. They fit no problem, and although they are pretty close, I don't see an issue. ![Thumbs Up](https://acurazine.com/forums/images/smilies/thumbsup.gif)
![](http://www.brockwayengineering.com/pics/tsx_front_left_wheel.jpg)
And clearance, for me mind you, would be about 4mm. That's just me though.
mada51589
05-03-2022 08:54 PM
asahrts
09-04-2015 05:55 PM
nuldabz
09-03-2015 05:49 PM
