Will These rims Fit
Re: Will These rims Fit
Originally posted by lankanprince
WIll 18 x 7.5 with an offset of I believe +42 be okie...
I have the car lowered with the Eibach Prokit and Tokico Struts..
you might have to cut the plastic bumper tab with that setup and that will be it. if you camber correct, however, it could be a potential problem since the 42 offset is on the low side. lastly, tires usually extend past the surface of the wheel so it's design will need to be factored in.
i have an 02 tl-s with 18x7.5/42, 225/40, prokits on stock struts and rear camber kit. originally, i had pirelli p7000ss and i only needed to trim the portion of the rear bumper that becomes part of the wheel arch. when i switched to bridgestone re750s with a more squared off tire shoulder, it started to rub the metal lip so that needed to be trimmed. if you don't have camber kits, then it might not matter. i did not have any problems with the front setup which does not have a camber kit installed.
