Will this setup work??
Old May 6, 2008 | 01:14 PM
MIZZ900's Avatar
PaKn-A-mAk-N-bAc-Of-Da-Ac
Im thinking of buying a set of 19's and just wondering if anyone can give me some advice on if this setup will work, or if anyone has done it- im not sure if the low offsets will work. I have a 04tl auto and it will be dropped on teins. thanks!
19X8.5 32 offset- front
19X9.5 35 offset - rear
Old May 6, 2008 | 03:06 PM
mindanaomoro's Avatar
You might want to check the postings / specs here
https://acurazine.com/forums/showthread.php?t=117535
Old May 11, 2008 | 10:42 PM
MIZZ900's Avatar
i did see that thread but i dont believe anyone had the 32 in the fronts....
Old May 12, 2008 | 12:35 AM
stillhere153's Avatar
94 DC4 RS LSV/Turbo
the front will be fine with 235 tires and some negative camber... the rear with 235 and slight negative camber will also work... you will not be able to run 245 tire in the rear without having to roll the fenders and having some negative camber
Old May 12, 2008 | 09:25 AM
rodneyc77's Avatar
Retired!!! ON TOP!!!
YES!!!
they will work.... 235/35 up front & 255/35 in the rear... you will have to roll your rear fenders and modify your Aspec kit in the rear...
Old May 13, 2008 | 12:18 AM
MIZZ900's Avatar
what do i have to do to modify the rear aspec kit.. i appreciate the help guys
Old May 13, 2008 | 05:20 AM
94 DC4 RS LSV/Turbo
there is a small spot that rubs the on the tire... you just have to snip it... you will see what spot it is once you get the wheels on
Old May 13, 2008 | 09:14 PM
MIZZ900's Avatar
cool guys, thanks again!
yesSIR-S
May 13, 2016 05:42 PM
o8 ENVII 8o
Nov 30, 2015 04:23 PM
acurajj
Sep 19, 2015 03:47 PM
Leester01
Sep 11, 2015 06:35 PM
KillerG
Sep 4, 2015 02:02 PM
