Will 285/25/20 Fit??
Considering buying a set of Sevas S22... Tires already included, but the tire size might be an issue.
Front: 20x8.5 with 245/30R20 Continental Sport Contact 2
Rear: 20x10 with 285/25R20 Continental Sport Contact 2
Will the rear fit after rolling my fenders? or will it still cause rubbing problem due to its size??
Originally Posted by flydog
Is this a serious question? Why not just spray a few cans of rubberized undercoating around the edge of the rims.
Those are the proper aspect ratios to run on the TL in order to stay as close as the stock diameter. They are thin, but it was you *should* be doing if your running 20"s on a TL, though I know most owners choose one ratio up.
99vtecaccord, it'll most likely rub because of the offset on these wheels. You might be able to get away with them without rolling your fenders if your lowered with a bit of negative camber and maybe stretched tires.
Are you smokin something ???
I hope this car is for trailers and shows with those rubber bands.
emailnatec
29
09-28-2018 04:27 PM
xsilverhawkx
09-28-2015 06:51 PM
