Will 255/35-19 fit our cars?
Yes but you will have to roll your quarters... also depending on your offset. I have that size on the rear right now (19x9.5 +35) and i am going to a 265/30zr19 this spring.
Yep depends on your rims offset.
If they are +30mm or less you might have to roll your fenders.
If they are +35mm or more you should be good.
For example if your wheels are 19x9.5 with +20mm offset
the biggest tires you could probably run is 235.
now on 19x9.5 with +40 offset you can run 255 tires.
nanos
11-12-2015 08:41 PM
