Wheels that clear Brembos in 6MT
Does anybody know if these wheels will clear the brembo brakes in my 6MT?
TSW SLOT
18X8 5-114.3 45C (chrome and gun metal)
Tires: FALKEN AZENIS ST-115 : 245/40ZR-18
I'm having a tough time finding wheels with screw designs that will fit.
We tried the Motoring REV 18x8 5-114.3 40M (machine finish)
and they didn't clear the Brembos.
If you know of any wheel that clears the brembos on 18 inch, please post it here.
thanks
TSW SLOT
thanks
Originally Posted by caball88
i believe with a 43mm offset it will clear the brembos, but most people say 45mm to be safe.
tires.com sells TSW wheels, try calling them and speaking to a representative. Or tirerack.com can also help you. The specs could be correct in every way but if the spokes don't clear it, they will not fit.
Good luck.
Originally Posted by AcuraTLjatt559
dont get TSW.. they are soft wheels.
btw 17 inch stock rim will clear the brembos w/out spacers.... i saw one @ meet on saturday. I didnt know that.
45 mm offset is the stock offset. You should be able to run anywhere 40-45mm offsets without a problem. (Some ppl are also running 35mm offsets, but that is not ideal).
By the way 18x10.5 is too wide. The widest I would go on a TL is 8.5 (which is what you are putting in the front). The width of that rear wheel would cause it to rub (plus you are doing a staggered setup on a FWD).
mada51589
05-03-2022 09:54 PM
rockyboy
01-25-2016 07:00 PM
Zonian22
11-14-2015 02:20 PM
