Wheel width
you are going to need hub rings that center bore is larger than the TL 64.1 mm ..
not sure if that 35mm offset is too close .. should be ok do a test fit on the car
my first set was 18 x 8.75 +35 with 235/40 rubber dropped on BC coils, and didn't even have to mess with the rears, only had to roll the fronts and shaved the tab. My current set up I am running 18 x 10 +25 with 245/40 and just now rolled the rears, still not running any camber kits - so I don't see 18x8 +35 and 18x9 +33 being too much of an issue, especially if you aren't lowered.
I agree on the hub rings - 73.1 to 64.1 is what you want.
Just to give you an idea - this is my current set up - just natural camber...
![Name: 20151017_084255.jpg
Size: 128.7 KB](https://acurazine.com/forums/attachments/3g-tl-tires-wheels-suspension-97/65038d1501399134-wheel-width-20151017_084255.jpg)
![](http://i84.photobucket.com/albums/k12/inlinefourH22/Mobile%20Uploads/2015-10/20151017_084255.jpg)
![](http://imagizer.imageshack.us/v2/800x600q90/903/5XF1mx.jpg)
Skier4lyfe303
07-05-2016 09:14 AM
Jimmy_D
01-07-2016 07:18 AM
bigzantt
12-27-2015 09:49 AM
