wheel/tires
wheel/tires
i am thinking of changing the oem tires and wheels and going with 17's. will 255/40/17 tires fit 17x8 wheels and will i have any rubbing issues with eibech pro springs. the wheels will be 43et, thanks in advance.
There was quite a lengthy thread a while back about 255/40-17 tires, however, my opinion is that the 255 requires a 8.5" minimum rim width, and also they are only 24.8" in diameter which makes them @ 1" smaller than the preferred 245/45-17 replacements. With the 43 offset, the wheel/tire would move out only 2 mm, or .08".
Here's the thread:
https://acurazine.com/forums/showthread.php?t=135535
Here's the thread:
I know a lot of people like 19's and some go 20, but for me personally, if I change wheels, I'd go 18.
So, why upgrade the wheels and stay at the stock 17? Just curious.
245/45-17 (25.7" Tall) tire height above rim 4.35"
245/40-18-(25.7" Tall) 3.65"
235/35-19-(25.5" Tall) 2.78"
ETC.
Just my taste.
Originally Posted by Soo ICeY
so quick question...you can put 245/45/17 on the 2003 TL-s rim???
there is a guy who has 255/40/17 tires on his stock wheels and it's a regular 3g tl and he has no problems with it, i don't think you will run into any problems if you put 245/45/17 on the oem wheels, that is what i am going to run on my 17's also.
1fatcrxnem1
22
06-01-2018 01:23 AM
