Wheel for Stock TL
Wheel for Stock TL
Hi, I have a 06' Acura TL currently using OEM Rims and was wondering if the size of the rim on tirerack.com for 17" tires fit all tires.
Such as:
http://www.tirerack.com/wheels/WheelCloseUpServlet?target=runWheelSearch&initialP artNumber=AR17E12BML&wheelMake=ASA&wheelModel=AR1& wheelFinish=Black+w%2FMach+Lip&showRear=no&autoMak e=Acura&autoModel=TL&autoYear=2006&autoModClar=Aut omatic+Transmission&filterSize=17&filterFinish=All &filterSpecial=false&filterBrand=All&filterNew=All &sort=Brand
or
http://www.tirerack.com/wheels/Wheel...All&sort=Brand
If that fits my stock tires.
Such as:
or
AZ Community Team
Received 7,770 Likes
You see where it says, "Rec. Tire Size: 235/45-17". That the optimal tire size and it is the same size as the OE tires.
Also, fyi, the stock wheel size is 17 x 8 and the offset is +45. Where it gets dicey is if you have the OE Brembo brakes or an after market BBK.
Other sizes fit (both other tire sizes and other wheel sizes) and Tire Rack is pretty conservative - if they say it'll fit, they'll be right the vast majority of the time. A lot of people swear by 255/40 R 17.
Finally, select a particular tire on Tire Rack. Then go to the SPECS link. That will show you the range of rim widths *recommended* for that tire.
AZ Community Team
If you're car has the factory "ACURA" Brembo brakes or an after market Big Brake Kit (BBK - they're a couple thousand dollars - you'll know if you've got it) then spoke design and back space become important.
With base brakes, pretty much any 17 x 8 with a +45 offset (down to +38 *I think*) will fit fine.
If you have a 2005 (?) or older, you're wheels will need TPMS or you'll get an error on the dash "dummy" light. You can either get new sensors and mount them or transfer your current sensors.
AZ Community Team
Thanks for the correction. I meant "or newer", but wasn't sure which year TPMS was introduced.
mtl_ilx
09-03-2015 09:58 PM
