Wheel spacers
Old Jan 8, 2009 | 07:57 PM
tihomirbg's Avatar
Question Wheel spacers
I recently got new wheels and I was supposed to get then in 19x8.5 but instead I got them in 19x8 and now the rear are pushed in a bit. What is the best way to get the wheels a bit more flush with the fender? Wheels spacers?
If yes, how much and where to buy from?
Old Jan 9, 2009 | 03:22 PM
bigmoetl1's Avatar
wdp skyhawk
yes try a 3 or 5 mm and on ebay
Old Jan 9, 2009 | 05:15 PM
tihomirbg's Avatar
Yes, as I said the wheels are 19x8 and I just got the fk 452 as 235/35/19 but it seems that wheel is kind of pushed in.
So, do you think 5 mm would do the job? At least get the wheels more flush if the fender.
BTW, would that be OK for the rear because the front sits OK. But rear is the one that needs a little more work.
Old Jan 9, 2009 | 05:43 PM
ABP_04TL's Avatar
6-SPEED LOVER
5mm should do the trick unless u wanna do 10mm
Old Jan 9, 2009 | 05:48 PM
tihomirbg's Avatar
is 10 mm would be too much? Do you think?
Lets talk about safety. Is it safe with the spacers on? Some were talking about wheel bearing problems.
Old Jan 9, 2009 | 06:02 PM
Trew's Avatar
I would think that spacers will put more stress on the lugs, since less of the lug is being screwed into the nut.
Also, regarding hubcentric rings... What happens when you add spacers? the wheel no longer sits on the hub. Wouldn't this cause vibration?
Input is appreciated.
Old Jan 9, 2009 | 06:34 PM
milk man's Avatar
how much are you dropped?
i think the biggest spacer you can put with out putting extended studs is 5mm anything more then that you have to put extended studs.the reason for that is because you wont be able to screw the lug nuts far enough in.
now if your dropped pretty low 245/35/19 with a 30 offset after the spacer, prob gonna need to roll the fenders ... but if your not dropped at all you shouldnt have a problem
i had 19x8 with a 30 offset and running 245/35 tires on them and i rubbed and needed to roll the fenders and trim the aspec ... was dropped prob 1.50 if that
hope this helps and if i m wrong please correct me
Old Jan 9, 2009 | 08:56 PM
tihomirbg's Avatar
I'm actually on Eibach springs, so it is 1" drop. Also, I think I did not mentioned it but the wheels are 35 offset
Old Jan 10, 2009 | 12:07 AM
ssmtl2nv's Avatar
2009 g37s 6mt
5mm ftw, pm stillherer153 he is our resident jdm whore....
Old Jan 10, 2009 | 03:53 PM
tihomirbg's Avatar
I just tried searching for any posts by this user stillherer153 but could not find any. Is this user still active?
Old Jan 10, 2009 | 04:04 PM
Jesstzn's Avatar
its stillhere153
You had too many r's
Old Jan 10, 2009 | 04:52 PM
tihomirbg's Avatar
Originally Posted by Jesstzn
its stillhere153
Thanks. I new something was not right.
Old Jan 10, 2009 | 09:13 PM
stillhere153's Avatar
94 DC4 RS LSV/Turbo
just replied to your pm...
some people "trust" that adding a 5mm spacer will give you enough bite for the lugs...
me I would NOT chance it... all manufacturer's of quality wheel spacers give you extended studs accordingly...
ie. if you install a 15mm spacer, the studs will be 15mm longer than oem...
here is what happens with hubcentric wheel spacers... since they are not wheel centric
you stack em
} [] | 0
KEY
} hub
[] Spacer
| hub ring
0 Wheel Hub
vibration
you generally will not feel a vibration stacked this way because the only apparent wheel vibration would be steering wheel shimmy... since it is at the rear wheels, you wont even know
for fronts: I'd suggest aluminum hub rings... but even then there is a small chance of vibration (very unlikely tho)
Some of the best wheel spacers are made by
Ichiban (best bang for the buck) and wheeladapter.com (best customer service and custom made)
ichiban provides longer wheel studs
wheeladapter.com does not, but the wheel studs aren't expensive anyway
james357
Feb 13, 2016 02:37 PM
obert
Nov 14, 2015 09:59 PM
yvr_tsx
Sep 15, 2015 01:14 PM
jmoney2001
Sep 11, 2015 12:07 PM
mtl_ilx
Sep 3, 2015 09:48 AM
