wheel spacers
wheel spacers
Hello all. I'm a newbie to the site; and a newbie to aftermarket and performance upgrades in general. In my ignorance, I bought a set of chrome Limited 800 wheels from wheelsnext.com for my 2004 acura tl. I told the salesman that I had a manual transmission, but I didn't tell him that I had the brembo brakes. Hell, I didn't even know what that was at that time. To make a long story short, the wheels wouldn't fit. Wheelsnext.com won't take them back. So I have to make the best of the situation, right? After conducting a few experiments, I found that the wheels will fit with 10mm spacers. The problem now, is that the studs are too short. So I found a 25mm hub-centric spacer with studs. This fits. How safe is this?
[IMG]C:\Documents and Settings\TG1\Desktop\wheels[/IMG]
Welcome to the forums.
You have to get a host for your pictures, like Photobucket, and upload them there. That's why your picture didn't show. Check out this thread for tips on How To Post Pictures.
Before I can say anything about spacers I need to know more about wheels you got. Width and offset at least. Generally, if you have to use spacers you should use the smallest that would solve your problem, just replace studs with longer ones.
Your picture didn’t come on because it first has to be uploaded to some web site that allows linking and than linked to your post (just as you did). May be this one:
I tried to sign up using that screen name originally, but it didn't work, so I had to use a new name
what am I seeing with this picture?
On the picture you can see cross section of TL’s front wheel with Brambos. All measures are in millimeters. First 45 from left is the one you have problem with. You can make a template with those dimensions and check any wheel for clearing Brembos before you put it on.
jmoney2001
09-11-2015 12:07 PM
mtl_ilx
09-03-2015 09:48 AM
