wheel/ spacer question
Okay, so I recently purchased some new wheels with the dimensions 19x8.5 with a 45 offset. To my understanding our stock wheels have a 45 offset as well. Shouldnt the new wheels that i bought fit and clear the brembos on my 6mt because the offset is the same, or does it change when you increase the wheel size? I just got the tires on and i went to put these on and they hit my calipers... im confused! also if a spacer is needed how do i measure how many mm i need it to be?
put on a 5mm.
if it doesn't fit, put on another 5mm.
if it fits, you need a 10mm... lol
there's also 2mm and 3mm spacers but having 2 spacers imo is bad for the car.
if you need a 10mm spacer, make sure you get spacers with studs on them because stock studs will be too short for your lug nuts after 10mm spacer installed.
My Garage not
1 Post
the stock wheels are 17x8" with a 45mm offset. so the equivalent offset on your 19x 8.5" is 39mm which actually helps to clear the front calipers a little. the problem is that the spoke design on the 19's doesn't flare out enough to clear the brakes so just get a 5 or 10mm spacer like as2222222222 said.
if u can, exchange the rims for one with a slightly lower offset like 35-40mm. if u can't, just use a spacer on the fronts.
94 DC4 RS LSV/Turbo
since he mounted tires to the wheels there is no exchange possible, he will have to either run a 10mm spacer no question about it (5mm wont do it)
what is the exact wheel and tire size?
8AT > 6MT
Project Kics makes great spacers...
project Kics spacers came with studs on them, in my case, i knocked those out and bought a set of APR extedned studs in stead....
navtool.com
31
11-16-2015 08:30 PM
navtool.com
09-25-2015 05:15 PM
rboller
09-23-2015 02:49 PM
