Wheel size??
Wheel size??
I'm about to get some new wheels they are the varrstoen
es 2.2.2
i found them in
19x9.5 +30 front
19x10.5 +30 rear
My question is will they fit with this offset and is anyone running this exact size or should i go with the +22 if so what size tires for both offsets thanks (i did search could not find the +30 offset)
es 2.2.2
i found them in
19x9.5 +30 front
19x10.5 +30 rear
With a +22 offset and those rims widths, you would have a good deal or rim poking outside of the fender. I think a +30 would like fine. Tire size is also subjective depending on your goals, like how low you want to go and if you care about the tires being stretched or not.
Here is a thread where with someone running the same specs with a +20 offset and the rims stick out a lot. https://acurazine.com/forums/3g-tl-tires-wheels-suspension-97/my-new-shoes-861164/
nuldabz
09-03-2015 05:49 PM
Mugen TSX
Eastern Canada
09-01-2015 11:05 PM
