What size tires should I use?
I just bought a set of Axis Penta in a 19 x 8.5 with a 35 offset. I am lowering the car with Eibach pro kits with Tokico Shocks and I will be using Ingalls Camber kit to level out the rear wheels.
with a 235/35/19 will it rub? could I use a 245/35/19?
That setup will be very close, especially if you're lowering the car, as the 35 offset will extend the wheel 7/16" farther out toward the fender. I'd say not much clearance with either, without rolling the fender. Maybe someone else that has experience with the setup will chime in.
I am looking at a similar setup, I am planning on getting a set of 19 x 8.5 with a 42 offset. The tires that are on it are 225/35, I think those should fit without a problem, and I would like to drop the car someday but not soon, what will I have to do so I make sure my car is fine to drive, will I need to roll the fenders or get a camber kit or nothing at all?
cammy5
09-04-2015 11:26 PM
Mugen TSX
Eastern Canada
09-01-2015 11:05 PM
