What Is Offset And How Much Should I Get
I think am going to get some 17 inch Konig Imagines and i am wonder what offset is AND should i worry about it since i am only getting 17s.
thanks for the help guys
Blake:
Blake:
Re: HELP WITH SOME RIMS QUESTIONS PLEASE
Blake:
Blake:
What size tires? 205, 215?
The stock TL-S rims are 17 x 6.5 with I believe a +52 offset. The offset brings the tire in more (tuck) in relation to the fender. The higher the offset, the more it tucks in the rim/tire. I have 18x7.5 Konig's with 225/40's and +45 offset. I had a little rub after I installed my H&R sport springs. With 17" and a skinnier tire, should be no problems. Hope it helps. BB
Hey i think that the rims are going to be eather 17 times 8 or 7.8 ......
my car is not going to be lowered at all. At leastnot for now... how are your rims holding up ... and your 18 inch rims are rubbing you said.. I am going to keep the over all diameter of the tire the same.
WELL THANK YOU SO MUCH FOR HELPING ME
and i hope to here from you agian.
BLAKE
BLAKE
BLAKE
BLAKE
HEY THANKS AGAIN FOR HELPING ME. ALSO I WAS WONDERING ABOUT HOW YOUR RIMS ARE DOING. I AM ALWAYS WORRIED ABOUT THE RIMS WHEN I GET THEM TO COLLAPSE INWARD LIKE A PRINGLES CHIP. OR I WAS WORRIED ABOUT ANY OTHER DAMNAGE. DO YOU THINK THAT THIS KONIG RIM IS AS STRONG AS THE FACTORY RIMS. THANKS AGAIN.
BLAKE
BLAKE
Rims
BLAKE
BLAKE
I talked to the parts guy at my dealership today and he said that a +48 offset would be too much and not clear the inside of the well.
They have a 2002 WDP TL-S in the showroom that has 235/40/18's but he wasn't exactly sure the width of the wheels or the offset. It also has the Comptech springs and he said that they have done a couple with the 235/40/18's with no problems.
I really like these wheels and want to put Kumho's on them. Does anyone know if they will work?
Originally posted by dbox
hre wheels are bad ass but soft soft soft
Who was the clown that told you +48 was too much? Dude was a space cadet. If you are going with 225's or bigger, and possible drop, you might need 48+ or higher. If you don't drop, a +42 - +45 should work. Dealer guy was dense.
....correct me if I'm wrong, but doesn't the width of the wheel matter too when it comes to the offset? I mean... if a wheel is only 7" wide, then... can't you go a little lower in offset, than if you have a 8" wide wheel?
Here are the stats the setup in my 2002 TLS:
1.Rim size: (19" X 8" Axis SE7EN's)
2.Offset: (+40, but +45 is available and probably better)
3.Brand of tire: (Falken ZE-502 cheap, but very impressive)
4.Tire size: (235/35/19)
5.Drop amount (none yet - Comptechs on the way, but tested with two fat b@st@rds in the back seat, a full tank of gas, and a loaded trunk - tuckin')
6.Do they rub. (had to cut a VERY small part of the plastic on the rear part of the rear inner fender well, now there is absolutely no rubbing, +45 may prevent it completely without cutting)
7.Weight: (28 lbs.)
A word of advice - 19's are sweeeeeeeeet, 18's are for wimps.
7.Weight: (28 lbs.)
7.Weight: (28 lbs.)
7.Weight: (28 lbs.)
HRE Wheels
I'm pretty sure they're forged wheels... especially at what they're charging... every wheel is made to order (supposively). Check'em out on their website www.hrewheels.com
I actually found these on this site and I think the manufacturer is a company called Manaray. They are the Vector V5 model and they cost about $250 each. I don't think they are HRE's. Please correct me if I am wrong. I will not be purchasing them right away since we are headed into winter here in the Northeast. Damn, it actually snowed a little bit on the way into work on Monday morning. TOO EARLY FOR SNOW!!!!!
HRE Wheels start in the $500 - $600 EACH!!! Like I said... they are made to order... and custom fitted to your car. That's why they cost so much... It's like having a suit custom fitted to your body... directly from Giorgio Armani himself.... perfect fit. The problem is.... there's no why of getting any "deals" cause very little stores will carry HRE wheels around that'll fit your car. The Manaray VR5 wheels has that multi-piece look, but the rivets are fake... (I think).
neuronbob
23
Jul 16, 2019 10:48 AM
SinCityTLX
55
Oct 11, 2015 01:20 AM
