What kind of Lugs for Axis Milano???
Hey everyone,
Ok so I have had 19" axis milano's on my 06 TL with Pirelli RE960AS rubber. Problem I am having is dealing with vibrations. Talked to one of the wheel dealers around here since I just moved out to Springfield, MO and he said that Its either Hub Rings and/or Lugs. Now I am having problems figuring out what kind of lugs. Since I just realized that the lug wrench that came standard with the car wont even fit into the hole on the axis
So any answers gladly recommended
I think it requires the Cone shaped lugs.
If so I am thinking about the McGard Spline Lugs
PLEASE HELP
Daniel
PLEASE HELP
Daniel
My first Avatar....
If your wheels do not have hub centric rings, you will have vibrations.
the hub on the 06 TL is 64.1mm. The hub on the Axis wheels are bigger (don't remember the exact size) so, you need the rings to make the larger Axis wheel hub, fit the smaller Acura hub.
neuronbob
23
07-16-2019 10:48 AM
