What do I need to fit G37 rims?
I want to buy the G37 sport rims for my 5AT 06 TL stock. What exactly do I need to make this rims fit? Do I buy all front, all rear or both? What size spacers would I need? I did a search for g37 but couldnt find sure answer as to what I would need.
Thanks in advance.
Thanks in advance.
this guy here bought his TL with the G37 rims on...take a look:
https://acurazine.com/forums/3g-tl-photograph-gallery-96/joining-club-2004-tl-g37-wheels-758631/
https://acurazine.com/forums/showthread.php?t=758631
Thanks everyone for the help.
fronts of the G37 will not clear the brakes on stock brembos, I know this for a fact because I have test fitted those and they didn't fit. You will need a spacer, 10mm maybe but I am not sure, I'd go with 15mm just to be safe. You will also need some hub centric rings, as the hub bore on g37 is different than that of a TL. you can google the bore sizes for both cars and see what rings to get
Hub Centric ring to keep the car from vibrating. But also, I have a hard time believing that the wheels won't fit without a spacer as the stock G37 has bigger brakes than the TL has by a huge amount. 14" vs 12~" The calipers are also larger than the stock Brembos.
If you are talking about the G37 rims, you are incorrect.
OEM 19" 10 spoke G37 Sport wheels & tires
Front:
Wheels: 19"x8.5". Cast aluminum. Made for Nissan/Infiniti by Enkei. Weight: 26.5 lbs. Bolt pattern 114.3 x 5 Offset +43
Tires: Bridgestone Potenza RE050A 225/45/19 92W. UTQG 140AA, weight 27 lbs., tread depth 10/32"
Rear:
Wheels: 19"x9". Cast aluminum. Made for Nissan/Infiniti byEnkei. Weight: 27.5 lbs. Bolt pattern 114.3 x 5. Offset +45
Tires: Bridgestone Potenza RE050A 245/40/19 94W. UTQG 140AA, weight 30 lbs., tread depth 10/32"
Other: Lugs- 60° tapered seat, 2.7oz/76 grams each. OEM wheel locks- 3.2oz./91 grams each. Center caps .3oz./14 grams each. TPMS sensors (with valve stem & collar) 1.2oz/34 grams each (Part # 40700 -JK00B) .
Front:
Rear:
Front:
Rear:
Front:
Rear:
