What to consider when getting new tires / rims?
Ok Ive been reading the forums trying to learn more about rims / tires, but I have a couple of (basic) questions. Will the handling be different on a car with tires thar are 235 mm wide instead of 225 mm, or does it make any difference? Are bigger tires useful in any way besides looking better? Also, what do you need to keep in mind when getting new ones? thanks in advance...
Re: GAP
Originally posted by woodhaywoods
Will bigger wheels get rid of the gap in the wheel well, or is lowering it the only way to do it?
...and then there was One
Wider wheels will help with cornering, and acceleration (in ways). You will sacrifice rolling friction (slight mpg loss), you might not coast as far, and if you go too wide, you won't be able to accelerate as fast. But, about the widest you'll get on a TL is 8 inches, so no real worry about that. It will just grip better, and be more safe (my way of justifying it, haha).
Oh, and the lower the sidewall, the more the wheel gap "looks", so if you get bigger wheels with tires that have a low profile, you need to drrrrrrrop.
Sounds like a stupid question, but can someone explain what the offset is? I'm gonna be getting 18's soon, but only for looks not for performance/handling. I'm looking at Neepers but there is alot of size choices. Another Q, does anyone know the spec on the stock type s wheels? rolloing diameter, offset, ect......?
If anyone can help I would really appreciate it, THANX!
Re: What to consider when getting new tires / rims?
Tires that have more plies on its tread and its sidewall are more durable and would mean more chances of surviving most road hazards at high speeds.
Other factors such as tread design, UTQG features are secondary to me.
It truly varies driver to driver.
I have Goodyear Eagle GT+4 sized P225/55R16 V tires on my 2000 TL
on stock wheels and these tires have 6 plies on the tread and 2 plies on the side wall. Its a heavy tire too compared to most tires.
juniel
merc009
10-03-2015 12:59 AM
