What all is needed for type S front sway bar?
I have a 2004 tl and I’m planning on doing the type a front sway bar and have been reading al the threads and cannot determine exactly what I need. So do I need need the type a end links, 27mm bushings, and to drill out lca to 12mm? Do I need anything else?
You at least need to lower it I know but I will probably just get a ship to do it anyways since I will need an alignment after I just want to make sure I have all the parts but I will definentally be doing a progress rear sway bar myself
any reason you want to swap out the front sway bar? Honestly not worth it for the front, rear is worth it. It's better to get new shocks/springs and braces rather than dropping/lowering the subframe to replace the front bar.
pohljm (12-27-2018)
completely agree with the above comment by csm
-------Tim-------
I did it to my ‘04.
I did this a few months after putting the progress bar in rear. This was all prior to Koni’s.
To OP, yes to the new bushings/brackets, and endlinks, as well as drilling out LCA a lil, from 10mm-12mm. (Not postive on the mm size of endlinks, been awhile). Then alignment. You don’t have to drop the whole subframe, just loosen the front, then lower the rear.
ATLPanther
12-24-2018 06:57 PM
CarbonBronze08_TL
12-12-2018 03:04 AM
