What 19" specs will give you the flush look? Info here.
Old 11-15-2012, 05:45 PM
  #161
HE>i
05_NBP_TL's Avatar
235 will work also. it will just require more camber. I wouldn't worry about adding spacers with this setup. 19x9.5 +30 w/ 235-35 tire
Old 11-16-2012, 08:41 AM
  #162
Perdorian's Avatar
I just want the 235/35 tire to keep the speedomoter as close to stock as possible. I wonder how much camber I would need. But anyways thanks for the help. And after looking at the 19x9.5 +22 on 225/35. I may go this route now.
Old 11-21-2012, 07:07 AM
  #163
UA6LIN916's Avatar
19x9 +20 F with 225/35 right on the dot for me
Old 11-22-2012, 09:40 AM
  #164
9th Gear
baynham's Avatar
Thanks for this thread.
Old 11-22-2012, 06:39 PM
  #165
jonmizu's Avatar
Lol this thread juked me out... 19x9.5 +22 245/35 tires with eibach drop springs will not fit Will need to check what I can do with fender roll Name:  F3DF54FE-0D18-4A61-8B2C-163932A5A418-3102-0000013A6660004F.jpg
Old 11-22-2012, 06:43 PM
  #166
Italiano's Avatar
or run some camber^^^^
Old 11-22-2012, 06:48 PM
  #167
jonmizu's Avatar
Gotta see what I can do got a good deal on 19x9.5 +22 front and rear lol and trying to avoid 205 tires haha
Old 11-22-2012, 06:53 PM
  #168
Italiano's Avatar
Those specs in the back work great^^But in the front u would Poke like a Mo-Fo...
Shoot for a et30 in the front on a 9.5 width...
Old 11-22-2012, 09:35 PM
  #169
HE>i
05_NBP_TL's Avatar
Need to pick up some 225/35 tires (at least for the front), run more camber, roll fenders. I have the same setup front and rear. Lowered on coils to get the height perfect.
I would recommend 225/35 tires all around so you can rotate tires when needed.
Old 11-23-2012, 10:47 AM
  #170
pitorican's Avatar
what will it take to make these sit flush on my 2007 type s... i want a 19x9.5 all 4 they come a +38 offset and will they clear bbk with this offset??? ive seen one other car on here with these wheels with a custom build +30 offset and his cleared no spacers..
Old 11-24-2012, 06:36 PM
  #171
Italiano's Avatar
8mm-10mm spacers in the front....15mm spacer in the rear
Old 11-24-2012, 08:18 PM
  #172
I like turtles
IamaTL's Avatar
Brian will give you a great deal on a set of wheels.
Old 11-28-2012, 07:03 PM
  #173
blah
Vietnastee's Avatar
What do you guys think of these specs? Good enough to be kinda flush? hellaflush?
Fronts: 19x9.5 +22 with 225/35
Rears: 19x10.0 +20 with 235/35
Old 02-25-2013, 10:25 AM
  #174
rossv1's Avatar
I'm going to bump this up because I'm looking at a set of wheels with the same specs; 19x9.5 (f) and 19x10.5 (r) +22 all around with a 235/35 tire up front and a 245/35 tire out back. I'm lowered on Tein S-Techs...
Old 02-25-2013, 11:01 AM
  #175
CLtotheTL32's Avatar
Received 9,502 Likes on 6,173 Posts
So what's your question?
Old 02-25-2013, 11:17 AM
  #176
rossv1's Avatar
Will they be flush, hellaflush or what? Haha
Old 02-25-2013, 03:20 PM
  #177
Happy Holidays!
Silver_Surfer's Avatar
your 245s with those 19x10.5 at the rear will probably rub w/o rolling your fenders.
Old 02-25-2013, 04:09 PM
  #178
rossv1's Avatar
I'm planning on rolling my fenders and maybe pulling them too.
Should I wait until after I pick up the wheels to roll my fenders or could I go ahead and have them already done so the wheels will just be plug and play?
Old 02-25-2013, 09:30 PM
  #179
Alex Pham's Avatar
19x9 +38. ? Pref no stretch and min camber
Old 02-26-2013, 09:23 AM
  #180
Belleza's Avatar
Wuts up guys I have some g37 wheels on my Ssm tl they are 19x8.5 +43 in front and 19x9 +45 in back, i wil be going 2 and half inch drop what size spacers and size tires will I need to sit flush with stretched tires ?
Old 02-26-2013, 09:20 PM
  #181
slowburn089's Avatar
great info in here guys
Old 03-03-2013, 10:50 PM
  #182
Alex Pham's Avatar
19x9 +38 ? Would i need to roll my fenders? And what size tire recommended
Old 03-04-2013, 01:39 AM
  #183
vtecdude93's Avatar
19x8.5 +15 or 19x10+35 all 4 corners
Old 03-04-2013, 11:26 PM
  #184
07 NBP TL
Horditruck's Avatar
I have all four 19x8.5 +45 wheels wrapped with 235/35/19 tires. What size spacers would I need to achieve a flush look in the front and the rears(without having to roll/pull fenders)? Also, dropped about 1.5 inches.
Old 03-11-2013, 08:56 PM
  #185
greekguy000's Avatar
alright wheel experts
here's what i want
19x8.5 +35 front and 19x10 +35 rear
Its dropped on tein s techs with koni yellows
Any issues with the rear running that size wheel?
Also I'd like a healthy sized tire so that I wont have to worry about rashing the lips.
maybe a 265 or 275/30/19
help me out guys
Old 03-13-2013, 01:12 PM
  #186
Moved to the LOU
twigglius's Avatar
How far do you think the limits can be pushed running 235x35x19 on the front? Lowered about 1.75-2"... No camber kit.
Old 03-13-2013, 02:37 PM
  #187
blah
Vietnastee's Avatar
^ How wide of a rim are you planning to run in the front?
Old 03-13-2013, 02:58 PM
  #188
Moved to the LOU
twigglius's Avatar
9.5 if it's doable. Right now I am running 8.5+34 with no issues.
Old 03-13-2013, 03:14 PM
  #189
blah
Vietnastee's Avatar
Ballinfizzle ran 235/35 on his 9.5 +32 fronts and didn't have problems until he dumped his car.
I would go 9.5+30 and higher if you want to run a 235/35 tire.
Old 03-14-2013, 12:42 PM
  #190
Moved to the LOU
twigglius's Avatar
And his car was a beautiful thing to look at.
Old 03-14-2013, 01:13 PM
  #191
blah
Vietnastee's Avatar
This is the best picture I could find of ballinfizzle's 19x9.5+32 235/35 front setup. His front fenders look too straight and smooth, so I'm guessing he didn't roll or flare them. Hope this helps
Old 03-14-2013, 10:07 PM
  #192
Moved to the LOU
twigglius's Avatar
Looks like he was running 19x10 but in his farewell thread I can't find the offset. It was on his SC1's, right?
https://acurazine.com/forums/3g-tl-photograph-gallery-96/%7C%7C-ballinfizzle-%7C%7C-timeline-thread-2006-acura-tl-%5B56k-warning%5D-720070/
Old 03-15-2013, 12:40 AM
  #193
blah
Vietnastee's Avatar
He was running 19x9.5+32 fronts and 19x10+30 rears. He listed the specs in his FS thread.
Twigglius, check out the first post in this thread, b4forbrian also listed it.
twigglius (03-15-2013)
Old 03-18-2013, 06:01 PM
  #194
Thumbs up
awesome info in here
Old 03-21-2013, 03:07 PM
  #195
chopstix's Avatar
I have 19 X 9.5's all the way around +25 offset with 3mm spacer in rear. 235's work with no issues, rolled rear fenders sittin on coilovers.
Old 03-21-2013, 03:32 PM
  #196
6SPEED FEVER
EATSLEEPRACE's Avatar
I want 19" so bad ..but it's not a good experience when you live in NYC.......every time I look at this thread makes me want to go buy them again...lol
Old 03-21-2013, 06:28 PM
  #197
JoshD_99EM1's Avatar
If read through almost the entire post and have liked the responses and the pics of the white one on the xxr 530 is such a beautiful car. I would get them but I just got a set of 19's from a buddy for free, and I have yet to see anyone run this set up. Please let me know what id be looking at as far as camber/if tire stretch is needed.
05 Base 5at
Lowered on tein s tech
19x8 +22 front 245/35/19
19x9 +24 back 245/35/19
Gonna rub, camber kits, fender roll??? What all would be necessary to get these to fit. Not looking to go full flush, nor too much camber as it is my daily. Need it to be as logical and close to OEM spec as possible.
Or would I be better off just selling the wheels and getting something else?
Thanks for the input in advance!
Old 03-21-2013, 07:04 PM
  #198
pitorican's Avatar
^^Smaller tires like a 225/35/19 roll and pull and -camber^^
Old 03-21-2013, 07:14 PM
  #199
That much huh?
Maybe better off not wasting the money on the tires then. I def dont wanna go too far with the camber, And I will not pull my fenders. Damn, worth the shot.
Old 03-21-2013, 07:41 PM
  #200
pitorican's Avatar
To be honest with u its not That much work...I'm running varrstoen v3 19x9.5 +22 with 225/35/19 rolled and pulled and -2.9 front camber rear -2.8
Quick Reply: What 19" specs will give you the flush look? Info here.
