What 19" specs will give you the flush look? Info here.
#81
Hey B,I'm probaly gonna do the 19x9.5 et 30 front and 19x9.5 et 25 back for flushness...using a 225/35 tire in front and 235/35 back...fenders are rolled and lowered 2.5 inches. Will I still rub? Tnx B
#82
^ you should be fine with that setup... i rub in the front only when turned sharp and coming in and out of a drive way the front rubs... my rears dont rub at all... i think you should be fine with what you mentioned
#85
Alright guys am I'm crazy or will this actually work? New summer setup and I'm thinking: 19x8.5 +15 with 215's fronts and 19X10 +23 with 235's rears. I will be getting my rear fenders rolled this summer and I have coilovers so I'll probably drop it to where it's good enough. TIA guys
#86
#87
I haven't quite found my ideal TL yet but I'm planning ahead lol. I want to run Volk TE37's in the following sizing:
19x9.5 +22 front
19x10.5 +22 rear
The car will have full coilovers and camber kits and the fenders will be rolled (not pulled).
My question is what tire sizes would be ideal and about how much camber am I looking at if the car is relatively slammed.
Thanks ahead of time.
19x9.5 +22 front
19x10.5 +22 rear
#91
19x9.5 +22 front
19x10.5 +22 rear
19x9.5 +22 front
19x10.5 +22 rear
225/35-19 for the front.
#92
Thanks bud. Hopefully I don't have to run a ton of cmaber but I figured with those specs it would be mandatory.
#97
no problem
https://acurazine.com/forums/3g-tl-photograph-gallery-96/new-wheels-19x10s-265s-all-around-white-guy-setup-829705/
look at post 31 in that thread you should be fine with a 245 easily
btw what rims are you getting?
i plan on running a 19X11 on my next setup so that guy answered a lot of my questions
#99
I was thinking about buy a set up with 19x8.5 +15 and 19x10 +20. Will this work? Any fender mods? And what size tire will i have to run? Thanks for the help and thanks for this thread....
#100
for the rear you will definitely need a fender roll if you want to do a 19x10 +20 I think you'd need a 225 tire for that to work
#102
While the width is only 0.5" wider than stock, the offset is pretty low; you won't need spacers unless you are going very aggressive.
To put it in perspective, a 19x8.5 +15 is effectively the same as 19x9.5 +28.
SSM4DR (01-15-2012)
#103
#104
Thanks for answering jose-gsr's question which kind of gave me hints on what tire size I'll need. But just to be super sure lol, if I do 19X10 +23 in the rear. Would I need 225/35/19 tires also or would I be able to pull off 235/35/19? TIA
. Looking at tyrestretch, I think 225/35/19 on a 10 is a tab extreme for me.
SSM4DR (02-18-2012)
#106
If I want to go with 19x8.5 front with a 1 finger gap drop and 19x9.5 rear with a with a 1 1/2 finger gap drop, what offset do I need to run a setup to make my wheels with tires sit flush to the fenders.
#108
BANNED
^et is offset.
#110
I'm kind of late on this, but Thank you
. I already have the wheels
. Specs: 19x8.5 +22 front with 215/35/19 and 19x10 +23 with 235/35/19 in the rear. I'm just waiting for Spring to roll my fenders, throw the wheels on, adjust my coilovers back to lowering and get my free wheel alignment at Tires plus.
ET is same as offset, wheel offset: +27 ect. Or 18x8 +27
Actually it's 19X8.5 +15 up front.
#111
Received 6,470 Likes
^^^ Dude, use the Multi-Quote button! It's the middle icon in the lower right hand corner of each post. Reply to everyone in a single post that way!
SSM4DR (02-21-2012)
#112
I know this is 19" thread... BUT What are you guys opinion, Im going for the "Flush" look.
VarrsToen 2.2.1
18x9.5 +12
235/40 on all 4 corners.
Will the Ingalls rear camber kit be ok since it pushes the wheel from the bottom & which camber kit for the front (if needed). I will be lowered on the HT Spec Coils. I know rears will have to be rolled, will the fronts also?
Major reason why I chose 18s Vs. 19s was since Im going low, I still wanted to have some tire to help maintain my ride quality.
Any and all suggestions are appreciated.
VarrsToen 2.2.1
18x9.5 +12
#115
08 TL & 12 ADV/ENT MDX
So I am planning on ordering some wheels and need help on which offset,size and tire size will work. My fenders are rolled all around and on coilovers with stock camber.
will this fit on the front
19x9 et 18 front and what tire size?
19x9.5 et 22 rear and what tire size?
will this setup work on the rear?
19x10 et 22 and what tire size?
Will it fit with stock camber?
Rims will take 4 months to get here just want to be able to get it right![Thumbs Up](https://acurazine.com/forums/images/smilies/thumbsup.gif)
Thanks for your help
KidChenz89 (04-26-2012)
#118
I just ordered 19x9 +38F 19X10 +36r I plan on using 10mm spacers in front to make it 19x9 +28, I'm dropped 2" and my rear fenders are rolled, I plan on using 225/35f 235/35r.
Will this rub in the fronts?
#119
On a 19x9.5 et 22, is it mandatory to stretch it with a 225/35 on the rear?...my rears are rolled really well with a ever so slight pull...running 2.5 degres negative camber tucking tire....I really want to run a 235...can I?
