Want some idea for 19" wheels
12 TL Tech, 10 MDX Elite
Hello,
I have a 07 TL WDP. And I am looKing for some 19" wheels for it.
I am thinking about these two wheels :1) Work Emotion XC8
2) Work VARIANZA SCHWERT SC1
What you guys think?? PLease give me some idea!!!
Thank You!!!
![](http://i166.photobucket.com/albums/u110/wingtt/2007%20Acura%20TL/40.jpg)
![](http://i166.photobucket.com/albums/u110/wingtt/2007%20Acura%20TL/44.jpg)
WORKEmotion XC8
![](http://i166.photobucket.com/albums/u110/wingtt/2007%20Acura%20TL/XC804.jpg)
![](http://i166.photobucket.com/albums/u110/wingtt/2007%20Acura%20TL/XC802.jpg)
![](http://i166.photobucket.com/albums/u110/wingtt/2007%20Acura%20TL/VARIANZASCHWERTSC1.jpg)
![](http://i166.photobucket.com/albums/u110/wingtt/2007%20Acura%20TL/VARIANZASCHWERTSC103.jpg)
Thank You!!!
WORKEmotion XC8
![](http://i166.photobucket.com/albums/u110/wingtt/2007%20Acura%20TL/VARIANZASCHWERTSC102.jpg)
Also i am thinking about the width on the rims stock is 17"x 8", i want 19"x8" or 19"x 9", but i have to find out will fit the the 9" width or not, and the tires i will go 235/35/19.......or 245/35/19.....or any suggestion??
My Garage not
1 Post
the best fit is the 19x8 with a 235/35 tire. a 245 tire fits better on a 8.5" width wheel, it's just a little too big for a 8". the 19x9 will fit front and back but just barely.
94 DC4 RS LSV/Turbo
if you go with the one I am leaning towards 19x8 is ideal since there is no reason for the wider wheel, unless you want a wide stance, if you go 19x9 you have to watch the offset, I believe +38 would be the lowest you could go without having rubbing problems
Stillhere153, Thanks for your info.
So if I go for the VARIANZA SCHWERT SC1 wheel 19x8, what is the lowest offset i can go?? do you know?? can i go +35? i want a deep lip on the wheel.
If i go with the XC8, i want the center of the wheel...... like deep in as much as possible.
I want to find out the lowest offset for both wheels and then i decide which wheel i will go for.
Thanks again!!
Thanks again!!
Cruising in my
Thanks again!!
Thanks again!!
I think I've seen you on Beyond before. There's a few of us on here now. Make sure you check the meets section every now and again for meets.
94 DC4 RS LSV/Turbo
With 19x8 the lowest you can go is +32 maybe +30 but that is pushing it
19x8.5 can go with +35
And as mentioned before with the 19x9 the lowest you can go is +38
(The reason I know is because I almost purchased 18x8.5 +30 work emotions, everyone on here was very thorough and provided on point info, which was that it will rub in the rear, so now I get to provide you with it.... Johnny Knoxville in The Ringer says: Go for gold!)
FizzyStatus!
![Nod](https://acurazine.com/forums/images/smilies/nod.gif)
OK!!!!!!!!!!!!!!!!!! I found out that the XC8 not fit the 07 TL!!!!!!!!!!!!!!!!!!!!!!
So I will go for the Varianza SC1 Brushed aluminum with black accent, with 19"x 8.5", +35 offset.
The shop give me a pic. of a 07 TL-s WDP, with other Work wheels, but not sure with the black accent or not, looks not bad with that set up, but i don't like the style of the wheels.
Here is the pics.........
![](http://i166.photobucket.com/albums/u110/wingtt/Picture024.jpg)
![](http://i166.photobucket.com/albums/u110/wingtt/Picture023.jpg)
Thank You guys for the idea!!!!!!!!!!
I decide to get the VARIANZA SCHWERT SC1, 19" x 8.5". Need at least 3 months to get them, and will be winter time when they get here....but i will post some pic when i get them.
Cruising in my
Hey wingt make sure you put your email down on my thread so we can get you out to the next meet.
Here's the link: https://acurazine.com/forums/showthr...hreadid=375639
Where did you order from and what offset did you gow with !
Sweet wheels.
Sweet wheels.
Sweet wheels.
The offset is +35mm!!
I order them from the local performance shop!
$595.00 CAD per wheel.
![Yum](https://acurazine.com/forums/images/smilies/yum.gif)
merc009
10-03-2015 12:59 AM
nuldabz
09-03-2015 05:49 PM
