VS-XX Wheel Fitment
VS-XX Wheel Fitment
Hello,
I was wondering if any of you could help me out with these wheels before I purchase them. I posted it on the "will this fit " thread in the wheel section but no response yet. I'm mainly worried about it fitting or not fitting over my BBK, but would like to know if i'll have any other fitment problems. The current owner says he has a 5mm spacer to clear his Rotoras so I'm hoping thats all I need to clear them.
• Work VS-XX Custom Gold
- 19x8.5 +32 offset - A Disk: 59mm Lip (Front)
- 19x9.5 +29 offset - O Disk: 84mm Lip (Rear)
• Falken FK452
- 215-35-19 (Front)
- 225-35-19 (Rear)
I'm lowered on coils and rear camber kit installed (also have a front camber kit that has yet to be installed). I will need to get my fenders shaved or rolled to get these bad boys to fit. Am I facing any problems ? Any advice would be great before I actually purchase these wheels that I can't even get to fit on to the car.
THANK YOU IN ADVANCE!!
• Falken FK452
- 215-35-19 (Front)
- 225-35-19 (Rear)
2014 Jeep SRT
I think you'll be fine. At most, you may need a 5mm spacer to clear the BBK. Definitely roll/shave your fenders just to be safe.
huystAr (02-14-2013)
blah
Like everyone else who posted.
Your fronts will be fine even with the 5mm spacer. I would go with a bigger spacer to make it more flush, but that's just me.
Your rear fenders will need a roll and that's about it. You can even go with a 235/35 tire in rear to make the front and rear tire stretch look the same.
You don't need to shave any fenders.
blah
I honestly don't know how flush you want it to look so it's really tough to say because you might be happy with it, but others won't.
5mm is a good choice to start. You can always do test fits and put like washers on each lug to see if you like it or not. Just don't go drive our car with the washers on there.
Just wanted to clear up some things I'm not 100% clear on. I've been trying to research to get a better understanding but couldn't find the answers.
My plan now is to get the tires unmounted, get iForged Water Diverter installed with 90 Degrees TPMS adapter attached to the TPMS. Does that sound correct? Hopefully I can get some feedback on that as well.
you will be good and really with those size tires might not even need to roll the fenders... i would actually depending on the look you want run wider tires put the 225 up front and run a 255 at the back... unless you plan on adding big spacers to get it pokin then those tires are fine.
^ thank you for answering justin!! yeah the set came with a brand new set of tires so i guess ill hold off on the fender roll until i go with the 225 for the fronts and 255 for the rears. dont want to have 4 215s laying around or trying to sell them...but we'll see if i change my mind on that lol. i'd personally rather have wider tires than add spacers so that'll be the route i go with.
JByron
01-08-2016 09:49 PM
nuldabz
09-03-2015 05:49 PM
