varrstoen reviews
#82
No, that's not bad at all. When it gets bad is when you are turning and hit a big bump, then you'll see deep cut lines. Going straight you'll have no issues.
So, moral of the story, if you are TURNING, go slow if you think there is a bump.
With regards to the tab, just where the fender meets the front bumper cover is probably where you are rubbing, you just need to dremel that down, or roll it with a roller. Either will work.
#84
I don't think he's getting up into this part. I think he's rubbing where the fender pinch weld starts to flare out, right before it reaches the front bumper cover. It's more common than rubbing n the inner tab, which, as I understand it, you can't even rub on unless you have removed the fender liner.
#85
Again, remember, TURNING and big BUMPS are your enemy. The rest of it will be fine, even if you don't do anything.
#86
most of us with rubbing issues have dremeled it (cut it)
#87
alright im just gonna keep an eye on it and be very careful with turns on bumps! i just don't wanna ruin the tires but as stated before its not that bad so i will keep an eye on it!
#88
Ah, I see. I have seen pictures of another tab on the inside when the fender liner is removed, and that area can really cut a tire up as well.
#89
That's probably what you are rubbing on, and what needs to be cut a bit, or bent upwards.
#91
I just went out to take a pic but its too sunny and u cant see anything, but u can cut that piece? isn't its gonna cause the paint to chip and stuff and then rust? its the metal part on the actually fender correct? cause its like rolled then the metal kinda flares out. and when u mean dremmel sand it down or cut it ?
#92
I will, however, need to get the Skunk 2 camber kit next time, for the 275's. In a perfect world you'd have a camber kit front and rear to be able to do whatever you want, but there is a cost to that, certainly, and most guys don't want to pay it.
IF you do cut or dremel it, make sure to cover it in some sort of paint to keep it from rusting. Just use anything, it isn't visible, so brush on some model paint or something.
#94
BUT, THE PC ANSWER IS TO BE CAREFUL AND NEVER MODIFY YOUR CAR.
#98
so last night I used the dremel on the fender tab and got it down pretty good, looks good so far, I used touch up paint after. im hoping all is good. should I get front camber kit or really no need? im going to get a better alignment from a hunter machine. I will keep u updated.
#99
Getting a front and rear camber kit is really the only way to do fitment "right", as it allows you control, and sometimes it only comes down to a few degrees. Most people forgo the kits and just rub a little, because of the cost. I'd drive it a bit and see where you're at before buying anything.
