Varr ES3 Flush Specs
Looking to get 18 inch Varrstoen ES3's (CE28 reps) and can't figure out width and offsets for an 07 TLS w/brembo.
Is 9.5 +30 flush? Would +22 be more flush and does it require 225 tire and a fender pull?
Would +30 front & +22 rear fit better?
Is an 8.5 width wheel a more common choice w/ +35 offset?
I'm a little lost.
I plan to roll my fenders and lower the car beforehand on Tein Street Advance coils about 1.5 inches. Will add rear SPC camber arms but not wanting much camber. Maybe -1.5 or less. Not looking to pull the fenders either. I already have a weekend slammed car. Just looking for a clean, flush look.
Tires i'm guessing 235/40?
I can't really find anyone on here that has these wheels.
I'm a little lost.
mvp2765 (05-13-2015)
justnspace (05-13-2015)
it just depends on your goals.
my friend was selling these TE37s in this spec (18x9.5 +22) which is pretty perfect for TL's.
you could do a slightly less offset than my +22s if you're afraid that its too much.
yes, i get rubbing from the front fenders, presumably from the front fender tabs that i have been grinding off.
im running 245/40?/18s
basically; you cant guess what work you will need done...get the wheels on and see what you need done...front fender tabs def. need to go!
ive been using a hammer to "roll" the lip so it wont cut up my tires.
mvp2765 (05-14-2015)
emailnatec
29
09-28-2018 04:27 PM
