Utter n00b questions - Tire Pressure
Ok. I know you're supposed to put air in tires and check pressure when cold. How cold!
MID says 35 all around mid-day (75Degrees out here) and the car has been sitting for a while, so its cold.
In the morning, the MID will read 32psi. I understand why, but when exactly is the best to check the reading?
ibpeoplesayuseatiregauge (I'm getting one today lol).
BANNED
why would you need a tire guage if you have TPMS at your fingertips?
^well no.
since, it heats up during the day and where you do most of your driving, the pressure will increase!
so, I wouldnt worry about the low temps/low pressure in the mornings.
as by the time you reach your destination, your tire should be well heated and in the correct pressure range.
if not in the correct pressure range then I would add air.
There's really no hard and fast rule about time of day/temp to check tire pressure. The main issue is to check them before driving or within only 1-2 miles after starting driving. If the car has been driven, then it's best to wait 3 hours or so before checking pressure.
I usually check mine on the weekends before I drive the car.
the correct way to check your tire pressure is BEFORE you drive the car, 32 psi for base TL and 35 psi for Type S.
