Unique TSX A-spec on a TL Questions
Old 04-20-2014, 06:33 AM
frantinez63's Avatar
I recently purchased TSX A-spec wheels (18 x 7.5 +55 )and had the hub bored out to fit an acura legend (70.1 mm).
Now, I am wondering if these wheels will fit on a 2005 TL W/ brembo. I am assuming I will need hub rings at the very least.
Anyone have a similar situation?
Eric
Old 04-20-2014, 08:34 AM
CLtotheTL32's Avatar
Received 9,524 Likes on 6,180 Posts
The TL has a hub bore of 64.1mm, so you'll need to get some hubcentric rings.
It's possible that you might have to run a small spacer to clear the Brembos since those wheels are 10mm less aggressive and 0.5" narrower than the stock wheels offered with the 3G TL.
Have you test fitted them?
Old 04-20-2014, 03:53 PM
No, the TL isn't in my possession yet. I'm thinking they won't clear the brembo. Any ideas?
Thanks,
Eric
Old 04-20-2014, 04:12 PM
I honestly have no clue since I don't have Brembos.
Old 04-21-2014, 12:42 PM
Chapter Leader (Southeast Region)
Stephen00TL's Avatar
Thanks,
Eric
Your only choice is to sell the wheels or get tl aspec wheels
jriv7
05-08-2020 05:50 PM
wusty23jd
09-24-2015 11:41 AM
datadr
09-12-2015 09:12 PM
nuldabz
09-03-2015 05:49 PM
Quick Reply: Unique TSX A-spec on a TL Questions
