Type-S tire pressures
I am curious what the Type-S owners (not sure I want to hear from std TL owners unless they have the Type-S suspension) for tire pressures. I have played around with them on and off the track with some success in improving turn in and rotation.
AZ Track Whore
Wow where to begin....
factory spec is on the drivers door jam. experimenting with them is worth doing but street and track pressures and temps are apples and oranges dude. And TL-S suspension has little to any impact at all over another stock TL suspension. So maybe give me more info on what you've done thus far and how you've done it and I could be of more help to you.
AZ Community Team
Received 7,770 Likes
- we can hope, but I'm betting not.
OP, I run about 3 or 4 psi over the OM recommendations. You can see your Owners Manual here:
J-020: 3G TL Owners Manual, Navi Manuals & Warranty Booklet Links
https://acurazine.com/forums/3g-tl-2004-2008-93/j-020-3g-acura-tl-owners-manual-navi-manual-warranty-booklet-pdfs-851625/
https://acurazine.com/forums/showthread.php?t=851625
AZ Community Team
Type-S spec is 35/32 and I have softened it to about 33/32. THis is the first front wheel drive car I have owned and I race a Mazda RX-7 (RWD) so I have little experience with TP set-up. I am aware that there is a whole lot more weight up front so pressures will likely need to be higher. But I would like to minimize understeer. I should also note I do not drive like a chauffeur on the street although temps and pressures and nothing like what I would see on the track.
I'd bump the pressure up a bit. Then, to reduce under-steer, equalize the front and rear OR set the rear slightly higher than the front. For instance 33/36 or 34/37.
Also, to reduce under-steer, look at adding a Progress RSB and set it on 'med' or 'firm'.
At a couple of Auto-X events, I had to set cold pressure to ~42 - 45 (iirc) to get the applied polish marks to scrub off at the edge of the shoulder. FWIW.
socalsteve (09-24-2012)
AZ Track Whore
If you want to reduce the understeer with tire pressure alone then increase the rear tire pressure along with reducing the front pressure like you have already done. Give 32/36 a try and see if you see any difference. Though if just killing the understeer is mostly what you're after then the Progress rear sway is really all you'd need to get the job done.
JEEZ BEAR WAY TO BEAT ME TO IT!!!!!!!!
The following 2 users liked this post by vill0169:
Bearcat94 (09-24-2012),
I will be lapping ACS in the TL Type-S this Saturday as an instructor for an HPDE and I wanted to get some feed back on tire pressures for the track. I realize there are many variables and that I should really be probing the tire temps hot off the track but I will likely not have the bodies or time to perform that task.
I will be driving there my 35/32 cold pressure street set-up and would like to get an idea on what I should be looking for in terms of cold and hot pressures. I believe the last time I was lapping the Acura I was seeing hot lap temps in the neighborhood of 42/30-something as reported by the TP monitoring on track.
I guess I will watch the temps and pressure come up as we bring up the speed and see how the car wants to handle. I am somewhat unfamiliar with how tune a car that has so much weight up front. My inclination is the use more air for more weight but then again it is all about the contact patch. I hope I can get a probe on the tires after sessions.
AZ Track Whore
Ooops, I meant to say 32/35 F/R pressures... (where the hell are you flamers out there?)
37/40 cold or hot and street or track? and you're saying you're satisfied with anything +/- 3 or 4 psi from that? ?
So many factors in the "best" pressure but the tire itself is the largest factor. My old BFG Sports had the best traction at 44psi hot. My NT05s don't like anything above 35-36psi hot. If I adjust for 35psi on the track, once they cool off the low air pressure warning is on. I would get it close in a deserted area on the street and fine tune at the track.
The front tires have a larger change in pressure from cold to hot because they run hotter. Believe it or not, making the handling more neutral with the RSB actually reduced the amount of change in the fronts just a hair.
42 psi is pretty crazy high for a hot pressure man.... 37 psi hot all around has always worked pretty well for me. And I don't think I'd really trust the TPMS at all. Only a quality tire pressure gauge that's not affected by barometric pressure is worth using...and only hot pressure matters for tuning....
I'd start 30/32 cold and see where you end up and adjust from there. Usually works as a good baseline for me...and that's track obviously.
AZ Track Whore
I constantly use and compare the TPMS on my car with a high quality handheld dial TP guage. My sensors are very accurate.
30/32 is substantially lower that what we have discussed here above (32/35or36). I did get a chance to hit my tires with a pyrometer once and had good temps across all tires. I was running about 39 all around and turn in was good so I just left it there. I did not have much time to play around with my car but it was a good day overall - except for when I took out a CTS-V to give some demo rides for some of the people and lost a fuel pump, I think. After confirming it is the pump I found where the wiring has melted for some people so I'm waiting to hear more.
I said 30/32 cold at the track when looking for about 37 hot. Nothing about street or hot pressures. gaining 8-10psi on track is easy to do (with most tire setups) hence me saying that.
What gauge do you use? and what tire temps were you seeing with what spread from inside to outside?
As far as tire temps, I did not record them because I was short on time and just checking to see if I was in the ballpark. However I believe I saw low 160s on the fronts and mid 140s in the rear. I had a deviation of less that 5 degrees across the tire which, again, was satisfactory for me on DOT tires where I am at teaching speeds and not track record speeds.
Stay Out Of the Left Lane
Received 1,237 Likes
An interesting read and subscribed to get updates.
Temps in New England have started to drop and during the morning commute temps are already in the 40's and 50's. Have already noted 3-4 PSI drop. Added air the other day and am running 36F and 33R again. But again being in New England temps are forecasted to be in the upper 60's again soon..........
mugen_kid
11-13-2015 10:38 PM
NBP_BALLER
09-23-2015 08:18 PM
