^ Looks good
part numbers
http://m.ebay.com/itm/301129453327?nav=SEARCHJust for fun but these guys claim to have "all four part numbers avail". What gives?
^^^^The parts guys at Curry are clueless. They sold both A and B kits to 3 Azine members who specifically requested the MT kit:
https://acurazine.com/forums/showpos...5&postcount=53 https://acurazine.com/forums/showpos...4&postcount=58 |
^^curry told me that 202A superseded 201A which superseded 200A (the original 6MT Aspec for the 04-06).
It was not confidence inspiring when the guy answering the phone when I called one time, had no clue what Aspec was. The only guys over there that have any clue are the managers. The little minions are not well versed in the Aspec parts line up. :whyme: |
I am now seriously interested in the A Spec suspension. I like the look of it being OEM and doesn't hurt the alignment specs as much
Originally Posted by ScoobyTL
(Post 14948528)
Is the Progress 24mm bar (with the soft bushings) on a TL-S the best choice for better/flatter but not "hairy" cornering? I'm on stock suspension otherwise...
Picked up my Aspec suspension today. The serial numbers on the actual parts are not what I expected.
08W60-SEP-2M10-Ca & 08W60-SEP-2M10-Ba Any thoughts? |
^^the part numbers on the damper itself are designated Lt. And Rt. on the front with the specific lettering. This is solely for Acura parts tracking (what I was told). The rears have the same lettering and part number on the damper.
If you look at your stock suspension you will see that the fronts have different letter designations vs. the rear. The parts will fit regardless. The "kit" number is different than the actual damper P/N. |
Originally Posted by zoostation
(Post 14961454)
Ok cool. Just wanted to ensure I'm installing A-Spec
Has anyone experienced quicker tire wear going from Base to A-spec even after setting toe to zero? I have 144k on my TL so im thinking the shocks need replaced... So im considering the A-spec upgrade maybe next year. This year is brakes, 2 tires, and those lovely compliance bushings :/
Tire wear isn't a problem with aspec. Waiting 144,000 miles is a problem, the stock shocks are likely doing little to nothing. You should feel a huge difference going from a 144,000 mile stock worn out suspension to aspec.
Originally Posted by 0utl
(Post 14964490)
Originally Posted by jhumbo
(Post 14965240)
Quite the opposite sir. I had 160k on my TL with the OEM base suspension and was seeing premature tire wear on the fronts due to the worn suspension. Moved to the A-Spec suspension and got new tires at that point. 35k later, the tires still had tons of life left with nice even wear.
(Post 14966141)
Great thank you for the feedback! How does it feel on the bumpy roads vs base? So no worries with rear camber out of spec with the small height deduction? I would love to put on the A-spec this year but I already purchased brakes and the compliance bushings need done and will need 2 tires come fall. Or does it make sense to due shocks before bushings since the worn shocks may stress the bushings and cause them to wear prematurely along with the tires? Or suck it up and do it all :thumbsup: thats over $1k though :/
I still can't make up my mind Between A-spec or the Type S!
(Post 14977201)
I don't think A-Spec is rough at all, still comfortable and the car feels more planted to the road. |
^ +1
+2
The A-Spec kit isn't bad in price, especially if you know someone that can get a discount on the whole kit. Hopefully I know someone lol
I'm going to order my A Spec Suspension 08W60-SEP-201B for my AT 2008 TL TYPE S. Hopefully the drop will be at least 1/2" to 3/4" after a few days. I will take before and after pictures.
I got confirmation that this is the right part number for my 2008 Acura TL TYPE S AT. I know it is for the Manual TL TYPE S but I want to drop in the front :D |
Here is a photo after the suspension settled and added type s wheels with 255-40-17 tires
http://i1272.photobucket.com/albums/...ps0b267c3b.jpg |
I'm looking to pick up some A-spec springs for my 04 6MT.
Are these the correct part numbers? 08W60-SEP-2M10-Ca & 08W60-SEP-2M10-Ba |
That's for the individual strut. The part number your looking for is 08W60-SEP-201B. Which is for the set of four. I just got mine from http://www.oemacuraparts.com. Use promo code SWOOSH to cut your shipping in half. If your from canada PM me I'll let you know how to bring it over with out duty or tax. Good luck.
Originally Posted by Stephen00TL
(Post 14995070)
Originally Posted by Kajan_8
(Post 15039491)
Originally Posted by Bruce Banner
(Post 15042738)
Are the springs not sold alone? I was thinking of putting the springs on koni yellows.
(Post 15042738)
(Post 15042738)
(Post 15045752)
If you want I can check to see if the springs alone have a part number. But as far as I can think of there isn't a way around buying the springs as a set. I got mine from the states cause it's almost sold out in North America. I'll check though this week end when I get back into town. Good luck.
Out of luck man. It's got the part number for the whole thing. Sorry.
I read through this thread but might have skipped over the answer if it was in here but is the ASPEC suspension MT interchangeable between the auto and manual? I think the only difference between the two is the weight difference between the auto and manual.
BallinOnABuget and I are both thinking about going ASPEC. He's auto and I'm 6 speed manual. He'd sit a little lower as long being he has an automatic. :) |
Originally Posted by Boogsephine
(Post 15060159)
(Post 15060159)
New to the forum and new to the 3G TL family. I've always wanted a TL-S but couldn't afford them when they came out. Anyhow, I just purchased an '08 AT TL-S and want to improve the handling. With that being said, should I get the APEC kit or just change out the shocks and RSB with the Progressive one? I'm having a hard time locating a kit but do see one from an Acura Parts Dealer in FL for about $620 shipped. Looks like most kits are discontinued now. Unless someone here has one for sale for less???
Thanks in advance. |
A-spec springs
Hi all,
New to Acurazine as well with an 07 TL. Wish I purchased a-spec suspension when it was available. Now you can't even find a used set of A-spec springs let alone the MT version. A-spec springs look to be a great compromise with slight drop and increased performance. Currently have H&R sport springs with koni yellow. Drop is nice but a little too low for my taste only because I live in NY where potholes can be raised above ground over 2 inches. Just my :2cents:. |
4 Attachment(s)
Scraped bottom with this drop on a NY manhole. Can you believe it?!
Only New York would make manholes square.
