Two extremely random questions...
Alright guys, help me out...
1) 20mm Ichiba wheel adapter, can I use any generic hub ring or do I have to get one from ichiba? If so, where do they sell them?!
2) Are centercaps interchangeable given they're from the same company (Rays)? I want to get the ones from the Progressiv ME, but they're impossible to find as well...
TIA!
TIA!
B A N N E D
1: You probably have to get ichibas hub ring, Reason being is any ole' generic hub ring is only so thin, appx 1/4 of an inch, as for the 20mm spacers you need to have one as thick as the spacer itself, try call them up, im sure they'll hook u up with the correct hubrings.
2: im almost certain ray's has the same caps. I do know for volks you can which up the caps and what not between the models but not sure if you can put volk centercaps onto gramlights and vise versa. Contact mackin industries and find out and also you could probably buy it from them, they may require you show prove of recipt for the progressiv but just tell them that you want to use them on your lexions (im assuming) and show proof of that reciept << that is if they are interchangable.
08_UA7_Gr33k
02-11-2016 02:17 PM
detailersdomain
Wash & Wax
10-09-2015 10:13 PM
08_UA7_Gr33k
09-27-2015 01:56 PM
