Is It True....?
Old Aug 12, 2002 | 03:51 PM
MD'sTL-s's Avatar
Is It True....?
My friend who is going to be ASE Cert. told me that if I or anyone else lowers their TL-S with springs or struts or with both, and not get the right prillow ball upper mounts, it will lower their car the wrong way. Is It True that YOu need more than springs and struts to lower your car right?
Old Aug 12, 2002 | 04:16 PM
shawhite's Avatar
i would have to agree with your friend.... springs will lower the car but depending on the amount of drop you may need to buy the camber kit so you can adjust the camber.... if this is not considered you could experience very irregular tire wear (ex. wearing out only one side of the tire usually the side towards the car).... the best way to do this is to take your car to an alignment shop after you have added springs to your car so they can either align the front end or tell you that a camber kit would be needed to align the front end.....
neuronbob
3G RLX (2013+)
29
Aug 24, 2015 12:16 PM
a808tsx
Jan 31, 2012 02:17 PM
Rustyboy
Jun 7, 2009 10:48 PM
