TPMS fit any rims??
Desert Life Sucks!!
TPMS fit any rims??
I saw a guy running saleen rims and must say it looked really good.
Will a TPM Sensor fit on any rim?? Or do rims have to have special provisions to run sensors on them.
Sorry never had a car that required these and couldn't find much good info looking around.
AZ Community Team
Received 7,770 Likes
No, they won't fit "any" rim.
In some cases people have had to install straps or brackets on aftermarket wheels. For instance: http://www.iforged.com/store/product...products_id=11
I haven't seen that in quite some time, so maybe wheel companys have adapted/adjusted designs for sensor fitment.
![Dunno](https://acurazine.com/forums/images/smilies/dunno.gif)
sauceja (07-22-2011)
AZ Community Team
Limited more by the brakes than the sensors, I think.
Desert Life Sucks!!
Yeah, bad experience with ride quality last time I used spacers on 00 accord V6 to run 07 civic SI rims. Although it did look sweet.
Guess its back to Legends or TSW cadwells. To lip or not to lip????
Desert Life Sucks!!
Middle of barrel? can you explain or post a pic?
Did you re-use your tpms or did you buy new? I really don't wanna take tires off my rims and keep them for spares.
![](https://sphotos.ak.fbcdn.net/hphotos-ak-snc4/hs794.snc4/67482_147626745282691_100001060980474_250823_3617355_n.jpg)
![](http://forum.mazda6club.com/attachments/wheels-tires/77905d1299826468-i-need-pic-stock-rim-tpms-photo-5-.jpg)
![](https://sphotos.ak.fbcdn.net/hphotos-ak-snc4/hs026.snc4/33681_147626298616069_100001060980474_250822_870788_n.jpg)
Desert Life Sucks!!
Ahhhh that makes sense. Yeah I have been busy also. This is first time I have been home in 6 days. Work is crazy busy.
So if valve hole is on side then normal TPMS will fit no/limited problems and if in middle need an adapter.
Good to know.
Good to know.
about to install my new rims on my car. i was thinking of not taking the oem tpms out and installing in my new rims. i know the light will turn on but i heard you can take the tpms fuse out from under the hood? is this true?
BANNED
TPMS on the TL will automatically calibrate themselves within a few miles of driving. simple.
Desert Life Sucks!!
Found some more good info thought I would share in here.
Honda
http://www.hondatpms.com/fitment-types-honda.html
Acura
http://www.acura-tpms.com/#1
Honda
Acura
Desert Life Sucks!!
Shouldn't be but I found that it was cheaper or roughly same price just to go with the OEM ones.
Aftermarket should work fine though from what I hear.
Titanium2k2 (02-08-2012)
sorry I've been busy but this is what i mean by the valve in the middle of the rim (1st pic) The TPMS is normally used on wheels where the valve comes off the side of the wheel (2nd pic) so thats why you need the adapter (pic 3) if the valve hole is in the middle of the barrel.....and i used new TPMS on the wheels. i left the old ones on the OEM wheels and didn't want to go through the hassle of switching TPMS everytime i change wheels its just not worth it ( pics are not mine just found them on Google )
Usually you only have this problem on wheels that have "lips", cuz those don't have a center-drop channel, they have a small drop channel on the back of the wheel.
Some of the newer wheels with lips have TWO holes on them. one in the middle for the valve stem, and a second one in the drop channel on the back of the wheel to bolt in the sensor.
