TL's been a Bit weird lately
hey guys
For the past few days, my TL has been acting very strangely. I checked the air pressure and its at a steady 35PSI COLD. The problem is that the car will be driving nice and good, then suddenly it feels like the tires just lost their grip, and the car feels like its floating, like when theres no air in the tires. It happens every-where, on local streets and the highway. It happens from about 35 MPH to 90MPH. I have not felt any vibrations and the air hasn't been leaking at all.
Also lately, with the road being wet, the tires will skid very easily. I can go from the redlight barely accelerating (about 2.3K RPMS), and VSA will kick in trying to keep the car happy.
The only thing that I have noticed about the tires/suspension is that the inner edge of all the tires (towards the center of the car) are almost bald, but the center and outer edge is like new. I have the Michelin MX4M tires, they have about 20K on them. Nothing under the car is bent and the sway-bar bolts are nice and tight.
Any ideas on the problem?
Mod's, this was posted here because it deals with suspension and tires, so it doesn't really belong in the problem and fixes section.
Originally Posted by csmeance
hey guys
csmeance did you ever have the bump stops fixed with the TSB for the uneven tirewear?
EDIT - Here is the link: http://www.in.honda.com/Rjanisis/pubs/SB/B05-050.PDF
Originally Posted by Timeless
Could be that your alignment is way way off. If the inner edges of your tires are wearing then your camber may be out of whack. I'm not sure if a very poor alignment would affect the VSA though.
If your badly toed out then it will wear the insides of the tires ... as its doing this ists virtually dragging the tires on the roads.
If you lived in snow country you'd be in the ditch ...
I'd do an alignment.
Thats an alignment problem- on the rack it goes!
Originally Posted by BLACKURA_NY
yea typical camber wear
original tires? if so, 43k is alot. time for some new rubber!
aligning, camber and toe adjust will fix the issue, but wont bring your tires back to life
A-spec steering wheel ftw
wow. i always read about members whose dealership is like 50 - 100 miles away.. i couldnt imagine...
Rallye Acura is 4 miles from my house!
it wasn't until i shipped the car out here to MO that i realized how lucky i was that my dealer is so damn close.
My dealer is far from me, about 50 miles each way now, and boy does it suck when you hit rush hour traffic coming towards orlando.
MrHeeltoe
20
02-23-2023 01:54 PM
MrHeeltoe
09-29-2015 10:43 PM
MrHeeltoe
09-28-2015 05:43 PM
