Tire size
Old 04-12-2014 | 10:49 PM
jjordan420's Avatar
9th Gear
Tire size
I have read a million threads about tires for the 19x8.5 ron jon inspyres i just wanna know what are the biggest tires i can run without any rubbing....really dont wanna do the 235 35 r19....thanks
Old 04-12-2014 | 11:33 PM
paperboy42190's Avatar
whats wrong with 235 35 19?
Old 04-13-2014 | 12:46 PM
jjordan420's Avatar
9th Gear
i just didnt want to small of a tire try to save the rims with all the pot holes around here...and i didnt want it to ride rough like i heard some people say so i was wanting to go with like a 245 40 19 or something like that just dont know what size to go with to where it wont rub
Old 04-13-2014 | 08:12 PM
jjordan420's Avatar
9th Gear
anyone please lol im ordering tires tomorrow would like to know what would be best to get thanks
Old 04-13-2014 | 08:46 PM
Jordan... you are not under standing.
when you up size your rim diameter, YOU HAVE TO KEEP ROLLING diameter the same.
this is accomplished by reducing the size of the tire.
235/35/19 has an overall diameter of 25.48 in.
while the stock 235/45/17 has a overall diameter of 25.33 in.
you HAVE to keep them the same.
or else your speedometer will be off, which means your odometer will be off.
In addition to the tire size not being "proportional"to the wheel.
it will look awful if you run a taller sidewall tire.
if you want to run a taller tire, you shouldnt have went with 19's.
you can compare different tire sizes against the stock tire size using this website..
http://www.1010tires.com/Tools/Tire-Size-Calculator
Acura-OC (04-14-2014)
Old 04-13-2014 | 09:42 PM
jjordan420's Avatar
9th Gear
yeah obviously i wasn't understanding that's why i asked opinions on it i seen some people say run a 40 series tire so that's the reason i was asking thanks
Old 04-13-2014 | 10:22 PM
a 235/40/19 would be almost 5% taller in diameter, throwing things off by 5%.
Old 04-16-2014 | 11:35 AM
robocam's Avatar
Here's someone running 235/40R19s on the front (275/35R19s in the rear), dropped 1.5 inches. Yeah, your speedometer/odometer will be off, but only by a small amount. At 60mph, your speedometer will read 57.56mph.
I thought about doing this but I'm afraid the bigger overall diameter might upset the visual balance, and it sort of defeats the purpose of running 19s because now they look like 18s.
http://www.svensworldofwheels.com/autoxindex.html
Old 04-16-2014 | 01:02 PM
robocam's Avatar
I just came across this post that says those are 235/35R19s and 275/30R19s. Maybe the specs on the other site are a misprint.
https://acurazine.com/forums/showpos...&postcount=596
ron3.7
09-20-2015 11:39 PM
GhostTL09
09-19-2015 01:57 PM
coykiam
09-11-2015 03:43 PM
nuldabz
09-03-2015 05:49 PM
Quick Reply: Tire size
