Tire recommendation
And watch your traction control go crazy. That's just asking for trouble putting two different diameters on a TL.
I would never replace with a stock tire either. Way too much money for such an average tire. What you get depends on what you want out of it and what your climate is like.
Never too old to learn.
Looks like I'll need to watch my back every day! You really make the Forum a fun place to post!
Think you'd better look at the diameters again before making the statement. Just to refresh your memory, the diameter of the OE Michelin is 25.6" and a 245/45-17 is 25.7", no problems there that I can see. If one were to purchase your suggestion, an aftermarket 235/45-17, they are only 25.3" when new, or @ 5/16" smaller than the OE tire.
Yes, 235/45 is the same diameter as a 245/45
when i had my "06" tl and my oem tires went i purchased a pair of sumotomo's and had not 1 problem with them another brad that i had on another vehicle were kuhmo's if i am spelling it correctly and also a great tire wife cracked the rims numerous times with the kuhmo tire's and not so much as bubble we replaced the rims over and over again and the tires never gave out ..just my experience
You're gasping for straws. If that is your point of contention, then even a matching new OE Michelin wouldn't suffice as it also would be a different diameter when compared to the tires presently on the car, and we know that's not correct.
Can't get much closer:
Michelin HX MXM4
235/45R17
Diameter 25.6"
Pilot Sport PS2
245/45-17
Diameter 25.7"
Might want to check the specs just to verify.
It's a far better solution then starting off with an aftermarket 235/45 tire that is only 25.3".
Time for some breakfast then on to better topics.
Michelin HX MXM4
235/45R17
Diameter 25.6"
Pilot Sport PS2
245/45-17
Diameter 25.7"
Michelin HX MXM4
235/45R17
Diameter 25.6"
Pilot Sport PS2
245/45-17
Diameter 25.7"
Michelin HX MXM4
235/45R17
Diameter 25.6"
Pilot Sport PS2
245/45-17
Diameter 25.7"
There are variances from manufacturer to manufacturer. If you have a 235/45 and 245/45 and they're spec'd as the same diamter, either the specs are wrong or the label is wrong. I can't remember if they measure only the sidewall or if the tread is included and I'm too lazy to look it up.
Thanks for the heads up guys. I'm about to purchase new tires and it'll be nice to know that 235mm is just a suggestion. I noticed that my Blizzaks always looked a lot more stretched than other tires.
1fatcrxnem1
22
06-01-2018 01:23 AM
2007, 2008, 2008acuratltirerecommendation, 2354517, acura, hx, michelin, mxm4, pilot, recomendations, recommendation, tire, tires, tl, type
