Tire Pressure
TL-S driver
Tire Pressure
What should my tire pressure be on my 02' TL-S? I have stock rims with Continential on them. The door says 32psi but I'm reading that some of you guys are setting it higher? What are the advantages of doing that? What psi do you set it at?
I'm do about 33/34 psi. Higher pressure will increase your gas milage, but your handling may go down and you'll wear the tire more in the middle. I think I saw someone posting upwards of 40psi before.
lover and fighter
Um, you really ought to check the tire itself as well as consult with whomever sold and installed the tires for the best, everyday pressure. That being said, my Nittos sit at 36 psi...
booooo
Originally posted by A-Spec_Racer
I run 38 in front and 36 in the back. This is a performance car, so I wanna feel all the bumps. 32 is too soft, and I find I spin too much in wet weather.
:lol:
I love the new SN "sc354"
Originally posted by TL_DipLoMaT
:lol:
:lol:
check the tire and see what the maximum psi is and adjust it to your driving. higher wont reduce your handeling it will improve it (to a point) im running 40 on mine. but the higher you go the rougher the ride (slightly) and it will wear a little faster. just check them every now and then and see how there doing
New Life
Well, I think there is a little confusion about tire pressure here. First the car manufacturer specify that a certain pressure is require for the car to handle in the way that it was intended. So it doesn't matter if you change the tire or put different rims, you still have to put the 32psi that's recommended and posted on the car's door. Any lower and when the tire is cold it will be dangerously low, any higher and as heat builds up you're going to have a rock for a tire (too hard).
Also, over inflated tires will cause the center of the tire to wear very fast. Under inflated tires will cause the outter edges of the tire to wear fast.
Only when you are going to the track and want a little better traction, you can lower the pressure of the tire by maybe 2 or 4psi below 32 and you will have better contact, any lower and you will create drag.
One last thing, over inflated tires create a lot of stress on the suspension.
Keep it at 32psi.
Keep it at 32psi.
TL-S driver
thanks guys. I checked all the pressures on the tires today and they were ALL different!! I just got them installed on Thursday!!! The tire was hot because I just drove from work but they ranged from 41.5 down to 35psi. No wonder my car wasn't going straight! I set them all to 38psi because if I remember right when it cools it drops down to 34psi. Maybe I should have taken a little more air out. I'll see how they are tomorrow morning. Thanks for the feedback!
Keep it at 32psi.
Keep it at 32psi.
Let's remember the whole "Exploder" Firestone episode. Ford recommended a tire pressure on the door jam which was dangerously low, reason being the Exploders unstabe nature. You see the softer the tire the less responsive it is,= less rollovers.
Ok back to tl, 32psi is great all around and with conservitive driving the tire will wear evenly and give a good balance of preformance and comfort. BUT if you drive agessively the edges of the footprint will wear faster than the middle, Im bored
I like 36 front 34 rear on my Sumi's
Just remember guys, those of you with the stock Michelins on your car have a max pressure of 35 lbs. (varified by tirerack.com) I would start playin' with the higher settings till you get those things off of there.
lover and fighter
The bottom line truly is that ALL tires are different. Manufacturers of the tire recommend settings for pressure and I would follow that above anything...And Blasing is right, you start putting 40psi in your stock Michelins, you are destined for trouble with heavy, highspeed driving driving...
I wouldn't lower your pressure on the track - sidewall flex and roll over is not good for the tire or your handling on the track.
I would run higher pressure on the track to stiffen up that tire, not to stiff to loose traction though - it is a trial or error thing.
On the street - 32 to 34 psi cold is fine.
Originally posted by fsttyms1
mine said 44
mine said 44
My last set of Goodyear RS-A's on my old Talon are still going strong with 62,000 miles on them. That's ONE set of tires . They were at 6lbs. over mfr. label. Wonderfull gas mileage (sticker said 29hwy. but I wound up getting 39-41 hwy.), wearis nice and even, steering response improved etc....I hope I can so this!!
Originally posted by dano80g
I think he meant the drag strip. Lower the front psi for traction and pump up the rear for less rolling resistance.
mugen_kid
11-13-2015 10:38 PM
NBP_BALLER
09-23-2015 08:18 PM
CostcoFanAUS
09-18-2015 06:05 AM
HeloDown
09-08-2015 06:51 PM
