Ten Street Advance uneven height
Hi! New to the forums..but just started doing work to my TL so i will be posting here much more..however i do have a question.
I just installed Tein Street Advance coilovers. All were put together correctly and everything was seated as it should be, suspension was pre-loaded before tightening, etc.. and i adjusted them to 1" from the bottom all round per the instructions. However when i measure all 4 corners, the front left/drivers side sits a little lower than the others. Is this normal? Should i leave it or can i adjust that corner to be a little more even.
I measured on a flat/level garage floor to make sure it wasn't the surface.
Thanks!
Thanks!
ill also add that i noticed the lower control arm bushing on the drivers side is completely torn and needs replacing...could this contribute to it? the passenger side one is fine.
JD TL-S (07-21-2015)
How do you like the firmness ?
I have installed TEIN SS & SA on 3rd gen TL'S .
I like a FIRM ride with no bouncing.
When I had the TEIN SS or SA. I set the
Front coilovers to FULL firmness.
I am considering these Basics .
once you get it set up, its good. im at 8 in the front and 9 in the back and its firm enough. it's my daily driver with a 1yr old and a 4 yr old in the back, so i cant have it too firm in the back. it rides a little firmer than stock.
i'd like to be able to crank the firmness up slightly just to stop the car compressing so much over dips in the freeway at 60+mph speeds, however it rides smooth and doesnt rub, so its really not an issue. i wouldnt want to go with anything that didnt have the damper adjustment, i adjusted it quite a few times to get it set up.
Former Sponsor
Glad to see you corrected the height issue by fixing the bushing. I often recommend damping adjustable coilover to people who have a very specific stiffness they want their suspension to be. The Street Advance are great for this.
http://hoa.excelerateperformance.com.../i-525373.aspx
rockyboy
08-04-2024 10:35 AM
nanos
11-12-2015 08:41 PM
