Tein Street Advanced Coilover review
#122
sorry kix,
dont know why it didnt post my specs:
front: 19x8.5 +32 w/ 15mm spacer to clear brembos
rear: 19x10 +36 no spacer
gonna be flaring and rolling the fenders, i'll start a progress thread, sorry Eats
#125
Former Sponsor
For those that are interested we have TEIN Street Advance coilovers in stock and ready to ship.
http://store.excelerateperformance.c.../i-525373.aspx
#129
Bryan Chewpay...the Tein's are NOT for you, buddy. Stick with F&F, ISC, HTSPEC and Megan.
Tein's are for a great ride and pretty low...not slammed.
This is as low as they'll go (camber is corrected, though)
[/url]
[/url]
Undying Dreams (06-29-2012)
Undying Dreams (06-30-2012)
#136
Im in nyc bk and this is my tein advance set up 7 clicks from stiff front and 10 in the rear and i have it for about 6 weeks but since last week i've been hearing a light click or thump in the front left side when i drive over bumps etc. It doesnt happen all the time but its there and Im clueless to what could it be, any suggestion would be a + and my coilovers only have less than 150 miles on them....i was also thinking putting the stock back on and let the dealer DEAL with it(im still under full warranty)
#139
They look like this and can cause dumping sound over bumps if bad......have a mechanic check em out ,they are suppost to be stiff.......if not migh be hiring shock tower from so low!......
Last but not least and not common might be a faulty Coilover or assembled wrong!
o8 ENVII 8o (06-30-2012)
#142
With the Tein...I would imagine it's an install issue, or something along those lines...if you have a front camber kit (with the upper adjustable bolt) and are maxed on the coils, you are bottoming out on the shock tower!
If not, check the endlinks on your sway bars, but I bet something is loose.
#143
So the car in the pic is on Teins? If so I see no need to go lower IMHO
#144
#146
Hey eats, no tire wear yet, tires are still new and dialing in the suspension still, getting it aligned soon too, just found out that one of my wheels were leaking so I have to diassemble and reseal the wheel, what a pain.
#148
I'm on Heeltoe's page right now with a set of Advance in my shopping cart; trying to convince myself to put in my credit card info.
ahh. Maybe if it was just the cost of the Teins and not also top hat kit, camber kits, installation, etc.
#150
borrow the spring compressor and just swap tophats.
Adds about 45 min. total to the install...but still not bad IMO.
camber kit, you can easily get away with none for quite some time. With it set to almost all the way down I had -2 front camber and -2.5 rear...but with toe set properly, it was fine.
installation, with adjusting of the height takes about 4 hours if you know what you're doing.
Ask a couple of local forum members to help out and knock it out over lunch or something.
#155
Yes sir. I did, I didn't want to spend another 100 bucks on tophats and just reused my oem ones. I've done springs a bunch of times so wasn't intimidated by it. PLUS, I have a compressor in my garage!
Nichio (07-05-2012)
#160
Well mine have 60-70k on them (bought them used), and came with an EDFC which I was too lazy to install, so I sold it. Therefore I do not have the click assemblies (Yes I can buy them, but thats 60 bux)....
plus I have a click that just developed on my front drivers side when I go over a speed bump slow....what could that be? I figured it has the be the suspension considering I just had my rack replaced and decided to have Honda slap in a nice new Type-S front sway bar for me, so it cant be the endlinks since they are new (unless they messed up when drilling the bigger hole in the LCA)...but I cant get under my car to look until I move to my new place which has an actual garage instead of a freaking gravel road..
Also, how long do our top hats last? Do any of those parts ever wear out? I would like to reuse my existing ones, but want to make sure they are not causing any problems (which is why I am inclined to buy new ones)....This would be the last of my entire front end being replaced if I went through withit (new cv axles, LCA bushings, rack, tie rods all in the last year)
